20 Most Recent Quantaray Zoom 100-300mm f/4.5-6.7 for Nikon Questions & Answers
Quantaray 100-300mm Lens for Nikon
Yes the new nikon D60 needs lens with a built in a/f motor. Your lens will go on and work but you will
have to manual foucs
10/5/2008 8:45:36 AM • Quantaray Zoom... • Answered on Oct 05, 2008
I have a Quantaray 100 ` 300 mm zoom bought at Ritz.
Return to vendor for repair or replacement
6/11/2017 12:09:40 AM • Quantaray... • Answered on Jun 11, 2017
The focusing ring is hard to turn on my 28-200 quantaray lense for my nikon camera
Time for a CLA. The focus mechanism will is usually filled with grease, makes it smooth turning, if that grease separates it can make things difficult. Also, it could be something is misaligned with the helicoid. Here is a YouTube video that will explain how they work: https://www.youtube.com/watch?v=n_Lji91nIos
3/2/2016 6:39:56 PM • Quantaray... • Answered on Mar 02, 2016
Need manual for quantaray PZ-1 DSZ flash
You need to contact local dealer , Or if you have the Box, contact who made it. Or see if Manual can be downloaded from Product Web Site
1/6/2016 8:25:10 PM • Quantaray... • Answered on Jan 06, 2016
Quantaray tech-10 75-300mm NF AF F4-5.6 for Nikon. How do I unstick zoom?
Hi Nicolas. Normally, this problem comes from a loose screw and roller that makes the mechanism gets stucked.
11/10/2015 3:33:24 PM • Quantaray... • Answered on Nov 10, 2015
How can I get my cracked Quantaray lens repaired
Sorry, you have not said where your country of origin nor which lens needs repair, thus we cannot make any suggestions. There are numerous repair shops around the world. Doing a Google/Bing/Yahoo search will provide you repair shops; one may be close to you. Also, depending on the lens you may be better of replacing it with a more updated better quality one; just a thought.
7/2/2015 5:56:30 PM • Quantaray... • Answered on Jul 02, 2015
Hello, I own a Quantaray 28-90 MM zoom Macro lens. I would like to know its equivalent Nikon lens, which would be one of the following: 1) D or G type Nikkor 2) CPU Nikkor lens other th
I'm not sure why you want to know this. It is a lens fitted for a Pentax camera. Nikon does not make a 20-90 mm Macro lens. Then it has a aperture from 3,5 to 5,6. It never would work on a Nikon, unless you have an adapter and then it still only could be used in manual mode. You have to do all settings, manual. not only the focus, but also the aperture, shutter time and ISO settings. I use a Nikor 24-85 mm f 1:2,8-4 D Macro, 1:2. With this lens when in focus the object is only half the size of the original. I think it comes close to the 28-90, but it is at least 5 times as expensive. When you are really in for macro photography, you better choose a prime macro, like the 40 or 60 mm from Nikon. both are 2,8 and not as expensive as the zoom version. The results will be much sharper. When you are talking of equivalent, I don't know what part should be equivalent, because that is important to know. As long as the focal length is the same and the aperture, you can make the same perspective pictures on the same distance. Only when you buy a DX, or even e lans for a four thirds camera, still the focal length will be the same, but as soon as you put these lenses on a camera with a larger sensor you will get massive vignetting. A lens made for a full frame (35mm) camera, when used on a DX or four thirds camera, will give the same perspective and will give no vignetting on a camera with a smaller sensor.
2/1/2015 7:31:52 PM • Quantaray... • Answered on Feb 01, 2015
Looking for a lense support for a quantaray 75-200 mm lense
what do you mean, lens support? - a 75-200 is not usually long enough to warrant this, if you mean a support bracket to mount the lens to a tripod, instead of a camera mounting point? btw - sigma made all or most of the lenses for quantaray, so you might try looking this one up that way as well.
1/22/2015 6:16:14 AM • Quantaray... • Answered on Jan 22, 2015
Can a broken mounting ring be replaced? parts source?
You can get special device for fixing it. (Use ebay.com)
8/12/2014 1:50:04 AM • Quantaray... • Answered on Aug 12, 2014
How can I find out the settings available on a Quantaray 70-300 mm zoom lens?
Quantaray has made several different 70-300mm lenses so I'm not sure exactly which one you have. However, if the lens doesn't have a AF/M switch it's no big deal. Assuming it's an autofocus lens, it's always on. If you want to switch to manual focus, flip the switch on the camera body. If it's an older manual-focus Quantaray lens then the question is moot.
7/21/2014 8:45:15 PM • Quantaray... • Answered on Jul 21, 2014
Will quantaray lens for pentax AF 70-300 1:4 -5.6 fit sony a65?
No. Pentax and Sony use completely different lens mounts.
1/22/2014 12:56:15 AM • Quantaray... • Answered on Jan 22, 2014
Pictures are too bright with my canon rebel xsi
Would like to know the setting you have your camera on now??
11/14/2013 9:36:37 AM • Quantaray... • Answered on Nov 14, 2013
0answers
Lens Mount
Be the first to answer 7/28/2013 6:17:02 PM • Quantaray... • Posted on Jul 28, 2013Be the first to answer
Quantaray Zoom 100-300mm f/4.5-6.7 for Nikon Logo
Popular Tags
3 questions posted
Top Quantaray Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tony Parsons
Tony Parsons
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
View Most Popular
Quantaray Cameras
  • Quantaray Cameras
Most Popular Question
quantaray 100 300mm lens nikon
  • Cameras
