20 Most Recent Samsung ML2165W - ML-2165W Wireless Laser Printer Questions & Answers
Paper keep coming out wavy.. How can I fix that
"Wavy" paper is usually caused by something in the feed path catching. It can be lint build-up, dust or any number or things, including one or more rollers becoming too "slick" to feed the paper properly. My best suggestion is a vacuum cleaner, canned air and a good flashlight. Follow the user manual to remove as many of the serviceable parts (toner cartridge, drum, etc) as possible, cleaning each piece off with a dusting attachment. You do not want to blow toner around your home / office if it can be helped. Examine each part as you remove it to make sure it's normal. Look inside the printer along the paper path as much as you can; blow anything out using the canned air into the vacuum nozzle if practical. The good / bad thing about the ML2165W is that they're easily replaced with something better if you can't get it working properly. Great excuse to go color laser or duplex printer.
9/20/2016 3:02:29 AM • Samsung ML2165W... • Answered on Sep 20, 2016
Hi I got problem after firmware update.The orange light is continuously on. There is no paper jam. The green led light is flashing...as well as the blue square wps
hi try to make to do again firmware update, something went wrong on the previous update. the orange light is on becaouse the printer firmware is wrong, is in the upgrade mode.
9/2/2016 7:58:54 PM • Samsung ML2165W... • Answered on Sep 02, 2016
Blinking lights
Check if it has paper stuck inside
4/2/2015 6:40:05 PM • Samsung ML2165W... • Answered on Apr 02, 2015
Error message: Fuser unit failure #U1-2320
10/11/2014 6:05:57 PM • Samsung ML2165W... • Answered on Oct 11, 2014
How to change font size
The font size is determined by the document and the software, not the printer. If your printer is making the text a size different than that in the document, check your print settings to make sure that you have set the paper scale to something less than 100%.
8/24/2014 1:25:45 PM • Samsung ML2165W... • Answered on Aug 24, 2014
Ml-2165w keep disconnecting
This printer keeps disconnecting from the wireless network I assume. You may have new neighbors that have their WiFi router on the same channel as you and thus trampling your signal kicking your printer off. Login to your router and try changing the channel as there should be at least 11 different channels on most routers you can select to prevent this type of problem. Also think of any Bluetooth devices that might be in range of the printer as they operate at the same base frequency and many wireless routers (2.4ghz) and remove them from the area or turn them off.
8/20/2014 4:16:52 AM • Samsung ML2165W... • Answered on Aug 20, 2014
0answers
0answers
Samsung Printer C410 Series
Try downloading the new version of the software for this at: http://www.samsung.com/us/support/owners/product/ML-2165W/XAA
11/24/2013 4:48:56 PM • Samsung ML2165W... • Answered on Nov 24, 2013
I have a Samsung ML2165w It will not print
your roller has some problem. please contact your nearest samsung authorised service centre regarding this issue
10/18/2013 4:31:47 AM • Samsung ML2165W... • Answered on Oct 18, 2013
How to connect wi-fi printer to laptop
With a wireless router that you probably have for you laptop. Printer should be connected directly to the router, and all PC's in you home can use it as a network printer, so everyone can print on it. Whether connection between printer and router is Wi-Fi or cable is of no importance. The procedure of installation may be a little boggling for someone doing it the first time. As I remember you should start installing driver CD on you laptop, and it will tell you when to connect printer to it, and when the basic part of installation is over. This way you can use printer connected directly to you laptop via USB. Next it will offer you to set wireless parameters. If your router is set to automatic (DHCP) it will ask you to register printer on your home network and you must enter your wireless network SSID and password somewhere in your printer. It should not be too hard. You just have to fallow the instructions.If your friend comes over with a laptop and joins your wireless network, he still can't use your printer, because he's hasn't got drivers installed, so you'll have to do that part all over again, for every PC.
10/13/2013 4:48:14 PM • Samsung ML2165W... • Answered on Oct 13, 2013
How do I clear an error message on my Samsung ML2165W printer without erasing the memory
no message red light error
9/11/2013 1:15:08 PM • Samsung ML2165W... • Answered on Sep 11, 2013
0answers
Samsung ML2165W - ML-2165W Wireless Laser Printer Logo
29 questions posted
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Computers & Internet
Most Popular Question
change font size
  • Computers & Internet
