20 Most Recent Samsung 700Z COREI7-2675 15.6 8GB 750GB W7H Questions & Answers
check and make sure your video card is seated properly if it is my best guess without doing any testing is that your video graphic card is broken
Samsung 700Z... | Answered on Jan 16, 2015
Time to get a new motherboard installed at a repair shop.
Samsung 700Z... | Answered on Jun 25, 2012
Which password? If hdd then purchase a new hdd and start again as no data can be retrieved. If Windows password, there are companies on fleabay and some good laptop shops that can help you.
Samsung... | Answered 6 hours ago
Samsung lcd monitor b2030
is the power LED actually dead?
is the screen 100% dead
is he front menu OSD button dead.
if yes, yes, yes, then the monitor is DEAD. of AC power is ok.
learn this fact all monitors before magic year 2010
are dead, due to CCFL back lamps burned out.
and will cost 2 times new, to fix it.
your manual shows year 2009
if it try to buy screen it shows me , the main board has 2 highvoltage CCFL lamp jacks.
so CCFL are dead. most are, most died in the year 2014
if run every day for 5 years, they GO DEAD.
or less if run 20 hrs /day.
if parked on shelf for 10 years, it works. see? 20,000 hours life spans.
best is to buy a 2011 and up monitor cheap even used.
with LED back lamps. and enjoy a long lived monitor.
CCFL jacks right side ! back lamps that love to die.
Samsung... | Answered Yesterday
Your hard disk is damaged. The data you have on the hard disk could have been recovered when it started making noise. Looks like crashed heads of the disk. If it is under warantee, take it to the manufacturer for replacement.
Samsung... | Answered 3 days ago
Sometimes there's a pinhole in the cover of the CD player. A straightened paperclip can be inserted into that hole to force the door open. As you press the clip straight into the hole the door is forced outwards.
http://majorgeeks.com/Avira_UnErase_d5284.html
What is gone is gone? Far from it! Avira UnErase recovers data that have been deleted from the hard drive - either accidentally or as a result of a virus infection, an uninstaller or defective software. The danger of important data being lost forever is averted with Avira UnErase.
The private, non-commercial use of Avira UnErase Personal is free
Calendar the date and time should be in the bottom toolbar
click start control panel date and time you can make your adjustments to the date and time from there or right click on the date and time and you should see Adjust date and time tab hope this helps
Samsung... | Answered on May 23, 2019
it have a update application download it from google or mobile store..
Samsung... | Answered on May 20, 2019
Go to samsung.com and enter your type and model number. If not try manuals.com
Mike
Samsung... | Answered on May 19, 2019
Is that what are you wanting to know?
https://www.manualslib.com/products/Samsung-Syncmaster-T22b350-6122233.html
Aparently doesnt have a PDF version...
Erofflps.txt is not so much usable file, Next time when you will get this message, do not close this message, just open the task manager and see the process after that disable it from the startup (by typing the command msconfig in run box)
Samsung... | Answered on May 17, 2019
The error-code 1407 at a Mac has many sources. The most common known one is that you've tried to remove a file into the trash-can, but the file got locked by another process. Think about watching a movie, which is located at this drive, and while watching, you try to remove it.
The remedy is to first close all running programs. After this, you can retry to remove the file. If this still didn't solve the problem, please eject the drive inthe Finder-screen. remove the drive from the computer and reconnect it after a few seconds. Now it should be possible to remove this desired file.
Samsung... | Answered on May 16, 2019
What happens when you change the monitors to the different ports? Does the violet monitor stay violet when it is plugged into the other video port?
I am guessing that the monitor that is violet is using a VGA connection
The most common cause of a monitor displaying a pink or violet color cast is that one of the RGB conductors in the VGA cable is broken, or the plugs are not firmly seated in the sockets, leading to one color not firing on the monitor. Try a different cable. Try plugging it in with DVI instead.
Samsung... | Answered on May 10, 2019
Have you changed the toner or the drum to see where the problem is?
Bonjour Lucy Gauthier, il y a cette option sur le clavier, pour une raison quelconque, elle peut ne pas ?tre disponible; ? de nombreuses reprises pour d?marrer l'usine (recommencer ? neuf), je vous enverrai un lien pour vous guider au mieux.
D?sol? pour tout inconv?nient avec Frances.
Samsung... | Answered on May 04, 2019
Samsung 700Z COREI7-2675 15.6 8GB 750GB W7H Logo
3 questions posted
Top Samsung Computers & Internet Experts
asber
Stormi  Paulk
Stormi Paulk
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Computers & Internet
Most Popular Question
fix screen
  • Computers & Internet
