20 Most Recent
Sanyo Xacti DMX-C4 Digital Camera Questions & Answers
I have an Xacti C4
Base from the description of your problem the picture button on the camera's mechanism is already bad and that one needs to be open and check and also sometimes it needs to be replace.
Copying videos from the camera to the computer
Ruth when you put the media card into the pc it should read the card and perform and auto play if it does you need to chose open folder to view files. When you do this all the media should appear as thumbnails in the window.. What I do with my media is I will create a new folder on the desktop... right click on the computer screen and scroll to new highlight folder.. .name the folder what you want ... kids pix.//b-day party... etc... I find the easiest way .. and because I'm a visual person is to open the folder I created restore it down smaller on the screen so that both the files from the memory card and my new folder are opened side by side. highlight one image or file on the memory card hit cntrl+A and all should be highlighted ... now just drag them to the new folder that you created once they are they the card should be clean... if you happened to copy then just erase all the images off the card when they are in the folder... hope this helps
Why won't Sanyo Xacti camera does not power on after being charged?
not car moved this to camera
no model told at all
the batteries are no good or connections rusty on most
many of these are 13 years old and sold as new by liars endless on the web .
models
vcp-nnn (lots )
DMX-nnn (lots)
the endless list is here.
what it uses inside who knows lacking model
the battery is bad, or allowed to leak and damaged connectors.
While seeing through display area it shows blurred vision
Your camera has a feature called MF (Manual Focus) if it is switched to MF, the autofocus won\'t work. If on the right side of the screen is MF, you are sure the camera is in that mode. You can change that in Recording Menu 2.The manual is still online.Success
How to get my picture right side up
I'm thinking you mean it is upside down on the camera screen. ??? Old man told me one time. When you get tired of trying to make that thing work right - read the instruction.
Sanyo VPC-T1496 Battery issues
Talk to Kastar and tell them there battery messed up your camera. I am assuming the camera was working OK when you got it.
