20 Most Recent
Samsung C3303 Champ Unlocked Quad-Band Touchscreen Phone with FM Radio Stereo Bluetooth and microSD Slot - International Version - Black Questions & Answers
Downloaded jar invalid
you should have a jar and a jad files so you can install it from your phone. go and check google for a jad converter. with this, you can create a jad file if that jar application,
Why i am update my samsung champ c3303i
It's your call if you want to update it or not. Updates are released to fix some bugs or issues or even add additional function. Try to research first if a lot of users experience issues with their phone after the update or not.
Why i cannot connect to mobile internet
Call for your network provider and make a request to send you the internet settings. Once you have received the settings, Follow the instructions specified by your network provider.
MY LG TONE HBS-730 stuck on incorrect pin
i have samsung mobile
Here are some steps you can try:
Reset the Headset:
Turn off the headset.
Press and hold the REW (rewind) button and the PLAY/PAUSE/STOP button simultaneously for about 5 seconds until the LED indicator flashes purple.
The headset will reset, and you can try pairing it again.
Pairing with Samsung Mobile:
Make sure your Samsung mobile's Bluetooth is turned on.
Slide the power switch on the LG HBS-730 to the "ON" position.
The LED indicator on the headset will be solid blue, indicating it's in pairing mode.
On your Samsung mobile, go to the Bluetooth settings and search for new devices.
Select "LG HBS-730" from the list of devices.
If prompted for a passcode, enter "0000" (four zeros).
Once paired, you'll hear "Your headset paired."
Check Battery Level:
Press and hold the VOLUME DOWN button for 1 second to check the battery status. The audible alert will indicate the battery level (high, medium, or low).
Charge the Headset:
Connect the charger to the headset. While charging, the LED indicator will show a solid red light.
When charging is complete, the LED indicator will turn off.
Remember that the headset will automatically turn off if not paired within 3 minutes.
If these steps don't resolve the issue, refer to the HBS-730 User Manual for more detailed instructions.
Connect sony dr-tn200 bluetooth headset to samsung mx-h620 hifi
Bluetooth is a short-range (33 feet/10 meters) wireless technology that allows two Bluetooth-enabled devices to connect wirelessly and communicate between them. If your son's Samsung MX-H620 HIFI is not Bluetooth-enabled, the two devices will not be able to connect in any way. If the headset were corded (it is not because it is Bluetooth) you could plug its cord into the headphone (LINE/AUX IN) jack on the Samsung. if the Samsung system is not Bluetooth, the only option is to find a suitable Bluetooth adapter to make it Bluetooth-enabled. However, you can use the Sony headset to listen to music or make phone calls from Bluetooth-enabled devices that you own such as phone, tablet, iPod, iPad.
