20 Most Recent
Intuit QuickBooks: Pro 2005 for PC Questions & Answers
Unable to retrieve company file after closing it
You probably opened an old file. You will need to find the current file that you were using. Use the search and search for all files ending in .QBW
Check the dates they were last used (you don't want the one with the most current date since that was the old file that was opened.)
10/10/2022 6:55:50 AM •
Intuit...
Answered
on Oct 10, 2022
Quickbooks won't open
How we can Fix QuickBooks Stopped Working
1. Use of QuickBooks Repair Tools
- Download QuickBooks Repair Tools
- Save the file in a local folder in the desktop
- Shut down all the existing open programs and install these tools
- It takes 20 minutes to run a scan in the whole device
- After the tool has repaired the program restart console.
You can visit us for more information
9/3/2022 5:02:26 AM •
Intuit...
Answered
on Sep 03, 2022
Trying to install QB 2005
hi you can try downloading the flashplayer from the following url below:
http://www.brothersoft.com/macromedia-flash-player-59871.html
or get the recent version here: http://www.adobe.com/support/flashplayer/downloads.html
9/3/2022 4:59:05 AM •
Intuit...
Answered
on Sep 03, 2022
Error code 7149 when I
Solutions are given below-
Solution 1: Repair or Reinstall QuickBooks.
Solution 2: Repairing Windows Registry Key Files.
Solution 3: Remove Malware.
Solution 4: Disable antivirus for some time.
Solution 5: Close any conflicting programs.
Solution 6: Go for Disc Cleanup.
This may help you,
Rachel Gomez
9/3/2022 4:55:52 AM •
Intuit...
Answered
on Sep 03, 2022
Getting error codes 7065 and
Step 1: Download and install the QuickBooks Tool Hub
The QuickBooks Tool Hub helps fix common errors. For the best experience, we recommend using Tool Hub on Windows 10, 64-bit.
Close QuickBooks.
We recommend you download the most recent version (1.4.0.0) of the QuickBooks Tool Hub. Save the file somewhere you can easily find it (like your Downloads folder or your Windows desktop). Note: If you've already installed Tool Hub before, you can find out which version you have. Select the Home tab. The version will be displayed on the bottom right or you can select About to view the version.
Open the file you downloaded (QuickBooksToolHub.exe).
Follow the on-screen steps to install and agree to the terms and conditions.
When the install finishes, double-click the icon on your Windows desktop to open the tool hub.
I hope these steps will be helpful!
Mark Wilson
4/15/2021 5:40:31 PM •
Intuit...
Answered
on Apr 15, 2021
Error on Startup for Quickbooks Pro 2005
You can find the repair feature in the control panel add/remove programs window.
Open your control panel, click on add/remove programs, scroll down to QuickBooks and click remove (it won't you will be prompted to either repair or remove). Have you disk handy in case it prompts you for it.
9/5/2019 12:14:09 PM •
Intuit...
Answered
on Sep 05, 2019
Reconciling
If you are trying to reconcile to your bank balance, you should not be reviewing the "deposit detail" report.
1) Go to "Banking" then "Reconcile"
2) If the "Opening Balance" is incorrect, then close the "reconcile" window and go to "Reports" then "Banking" then "Bank Reconciliation Discrepancy" report. (This report will reveal what changed after your last successful reconciliation).
3) If the "Opening Balance" is correct, then you want to press "continue" to focus on the bottom of the window, which reveals "total deposits marked as cleared". If you have duplicates, you will see them on the right side of the screen, but the ultimate goal is to have a "Deposits Total" (in QuickBooks) that agrees with the "Deposits Total" (per Bank Statement).
The "Deposit Detail" report is a "Journal Report" to show you details of historical deposit records, Has nothing to do with "reconciling" your current bank balance.
6/8/2019 7:35:29 AM •
Intuit...
Answered
on Jun 08, 2019
How can i make quickbooks 2005 run on a vista
Here is how to load and activate Quickbooks 2005 on Vista...
First of all, if you already have an activated copy of QuickBooks 2005 on another computer open it and go to "help" "my license information" and print this out so you have the details needed for activating your reinstalled copy (you don't need a fresh activation key and you may have trouble getting one as QuickBooks 2005 is no longer supported by Intuit).
On your new Vista computer, insert the QuickBooks CD but cancel any program install windows that pop up. Go to my computer and find setup.exe on the CD, right click and select the option to "run as administrator"
Once installed, navigate to the QuickBooks folder on your hard drive (typically C:\Program Files\Intuit\QuickBooks) right click on QB32.exe and on the compatibility tab select both Disable visual themes" and "run as adminstrator". Now open this file to run QuickBooks and select "file" "Update QuickBooks" to download and install all updates. QuickBooks will not work properly until you have downloaded the updates, closed and reopened the program.
I had problems with activation but I got around this by unplugging my network cable so that I had no internet connection. If you run QuickBooks without an internet connection, when the screen pops up asking you to "activate" click next and the screen to enter your license details will appear. enter your details (printed out from your previous installation) and you are done. You can restore the internet connection and use QuickBooks 2005 normally.
Andrew
11/26/2018 10:20:07 AM •
Intuit...
Answered
on Nov 26, 2018
QuickBooks has experienced an error on startup
Step one is run scandisk. If you have a cross linked or corrupted file it will sort that out automactically. Step 2 is to google "where is the quickbooks repair feature".....odds are someone has used it before. Step 3.....save your Quickbooks database (in at least two places) and delete and reinstall Quickbooks if all else fails.
9/6/2017 12:13:25 PM •
Intuit...
Answered
on Sep 06, 2017
Quickbooks pro 2005 error 7168
Usually a license number, product code error. Often seen on pirated software, but can also come from a damaged install.
Be careful, trying to reinstall an older version like this can result in the product going back to an old release, and the update files are no longer available.
1/6/2017 8:30:41 PM •
Intuit...
Answered
on Jan 06, 2017
Quickbooks error 7136
This usually means the license number and the product code do not match the product. Often seen in cracked/pirated software.
1/6/2017 8:27:59 PM •
Intuit...
Answered
on Jan 06, 2017
