20 Most Recent
IBM (03R0329) Motherboard Questions & Answers
Want IBM i845G Drivers
What driver do you need? It will most likely be drivers for your motherboard. If you download belarc advisor from the link below it will tell you the exact model and manufacturer of your motherboard. Once you have the motherboard model number go to the manufactures website and find the downloads area and you should be able to use the model number to find most of the drivers that you will need.
http://www.belarc.com/free_download.html
Cannot get sound to work
if your computer came with
a motherboard disc the sound drivers could be on it
click start control panel
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question exclamation mark? ! or a red X
Right click to reinstall drivers
sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settings there
also
sounds and audio devices select advanced there might be a tick in the mute box
untick it
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar
if his does not fix the
problem
click start control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer hope this
helps
I cleaned my ibm thinkpad R40 motherboard and
These laptops usually have a switch that is activated when the cover is opened and thus the message. Would suggest talking to IBM support for a master password, that will help you thru and get the same cleared.
Ibm bios problem
ibm i845 bord date & time save nahi hota cell b change kia ha pls solve problem thx
Driver for motherboard i845G-ITE8712 ?
Most drivers would be available at Driverguide.com but this site would require registration and make sure you select no offers so that your email is not spammed.
