20 Most Recent
Acer Aspire Z5600 Z5610 Z5700 Z5710 Computer Power Button Board Questions & Answers
Power indicator is flashing orange when plugged
try to do a power drain , and that can be done by the below:
1. remove battery and power cord.
2. press power button for somelike 1minute.
3. Now switch the system on with power cord plugged but no battery and see if that helps, else leave a comment and i see what i can do to make it all smooth for yah. find me here too.
Facebook
Turnin on computer blank screen with white dash left hand corner
yah system is not recognizing yah HDD, or a memory stick in the usb ports, so consider ejecting the pendrive and try again, else you need to switch bus cables and jumpers on the HDD. At one point the HDD is dying off and posseses bad sectors hence holds the reader back from reaching sector for data.
#Newtoxtonia
How do i turn on the web cam
Check in My Computer / Computer see if the camera is listed there.
If it isn't then try a different camera
Terry
Power button
You need to count the beeps then go to google search for beeping codes then you will see the codes. Repost them herell
Terry
Acer Aspire Z5610
You may try inserting a wireless or wired mouse in to a USB port to get some activity. As long as your screen comes up, the movement of the screen should be taken over by the mouse and temporarily bypass the touch screen application. You need to go to Acre, at their Web Site and download the drivers to allow the touch screen to operated. If after all your efforts fail; the unit needs a professional technicians services.
Tv signal
get the right software for your device and make sure you set it to the right country code or regional code. have fun after.#
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER.
this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done.
Acer X1110 data projector Standard throw projector..
did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2)
did you read owners manual page 32 yet, errors.
LED codes.?
there are 4 LED, and all 4 matter, projector turned (ON) (not one =1)
also in pairs glowing and also if blinking or not, so read page 32
it tells all that.
my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,.
https://manualzz.com/doc/49497108/acer-x1110-user-manual
some have dust filtler
a shop first cleans is out first, and check fan RPM with and LED tachometer.
this is all SOP.
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
