20 Most Recent
Acer Aspire One D270-1375 Atom N2600 1 Questions & Answers
How to run diagnostic form a hDD external enclosure
I am not understanding what you are trying to do. Are you trying to install an os on an external drive?
You can only do that on a drive not an enclosure.
Terry
How to create a new partition on the selected unused space
Hi Gregorio, you will need to state what operating system you are using to answer more clearly.
If you are using WinXP, Vista or Win7, right click om 'My Computer" then "Manage" then "Disk Manager". Select the disk and right click on the open space, "Create Partition" and Format. Hope that helps.
Forgot the admin password to login to windows
You may have trouble getting an answer to your guestion. I am not saying you are a thief but what I am saying is the password is to protect the owner's files from thieves. I suggest you take it into a computer repair shop like Best Buy and they can vefify your idenity and clear the password.
Terry
Acer aspire D270 wireless capablity turned off
Fix Driver Solution In Windows-Start-Control-Panel-Device Manager then search through the list for the element of distress. If it's Audio, it is in the Sound-Video-Game Controllers whereby left clicking on that section will open up a window indicating your electronic devices. A video Camera-Sound Source may show up and if you Right Click on that line you get a message Update Software? You will get another option the Search On-Line Note-you must have internet access for this feature- and say yes, and allow a search to ensue. If you have the Best Driver installed a message stating so will appear- if not you will get an updated driver and it will be installed for you automatically. The other method is to go to the Manufactures Web Site and Support area. Input the necessary data re Model, etc. and look for Drivers. Update ALL new drivers at the same time and install them accordingly.
Low graphic resolution
go to device manager to display adapter ; if is ok on the descktop click right buton mouse and select screen resolution and choose
Where is the wireless switch
it's a fn function ; look up on the keyboard and combine the fn key left down the keyboard with a "f" function key
How to install 2gb ram in acer aspire one D270-1375
Turn off power and remove battery pack and make sure it is not plugged in. Remove screws from back panel exposing RAM ports. There will be two spring clips that can pushed out to release the ram modules. Remove the old RAM modules and insert the new Ram modules in reverse order and assemble netbook. Power Up and enjoy.
