20 Most Recent
Acer Aspire 5552-3691-24271 Laptop Questions & Answers
Can't download anything on my Acer Aspire 5552-3691
I don't see a question above, so I'll just assume that you're asking how to fix your computer so that you can connect to the internet. Is that correct?
If so and since you have reset your computer back to factory settings, you should check that all of your software is updated to the latest versions. This would include your operating system and drivers.
Then, you should check that your computer can connect to the internet via ethernet (RJ-45) cable. You would want to directly connect your laptop using the ethernet cable to your router. If this works, you can move on to trying to connect via Wi-Fi. If this doesn't work, you should check that there are no software/driver issues and/or hardware issues with your computer.
If you are trying to connect via Wi-Fi, again you will want to check that all drivers and software are up to date (so that you are on the latest versions of your operating system and the Wi-Fi care inside your computer has the latest driver so that it can connect to your wireless router). Then you will want to attempt to connect and most likely re-input your Wi-Fi password.
Wont start up. the power button is on. the charge
If your laptop is not even POSTing at the BIOS screen, then it sounds like there is no video being output to the monitor. This can be caused by a dead video card or dead monitor. You can try to replace your video card or the monitor to repair it, or you can replace the laptop. Good luck.
Wont turn on...power button and charge lights on
REMOVE THE BATTERY AND TURN OFF THE PC AND POWER LID OFF AND HOLD DOWN THE POWER BUTTON FOR 30 SECONDS AND TRY IF NOT REMOVE THE BACK OF UR LAPTOP AND REMOVE ONE AT A TIME OF MEMORY SLOT AND SEE IF NOT AND U NEED REPLACING THE SCREEN SORRY MATE
Wifi
- Re-install the Adapter.
- Update Wi-Fi Drivers.
- Optimize Internet (Use reliable program for it like Reginout.)
- Disable Global Auto-Tuning Feature.
- Uninstall Remote Differential Compression API Support.
- Clear DNS.
- Upgrade your Wi-Fi's Antenna (If needed)
I hear feedback in my speakers
Your microphone volume is set too high. That causes ambient sounds to be amplified, picked up by the microphone and amplified even more.
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
