20 Most Recent Intel D845GLLY Motherboard Questions & Answers
I'm currently running windows xp
uninstal win xp and install win 10 win xp has not been supported by Microsoft for 10 years and the drivers are unreliable
2/10/2018 9:11:56 AM • Intel D845GLLY... • Answered on Feb 10, 2018
Drivers ethernet gigabit
Download the drivers.
9/27/2013 7:42:20 PM • Intel D845GLLY... • Answered on Sep 27, 2013
Drivers ethernet controller gigabit
Makers website.
9/27/2013 7:42:01 PM • Intel D845GLLY... • Answered on Sep 27, 2013
3 beeps after interval
Usually and indication of a memory issue. Power off the computer and pull all memory out. Place memory in one at a time into a slot and power on. If it fails on a particular chip, that would be the bad memory module. If it fails on every chip, the slot could be bad. If it does not fail and any chip, try each slot individually. It should fail on one slot and that would be a bad slot on the board.Hope this was helpful
3/12/2012 2:40:33 PM • Intel D845GLLY... • Answered on Mar 12, 2012
.i want to change my
make sure ram module its securely seated also this ram might not be compatable with your computer try to keep the same type of ram you already have is it ddr2 or ddr3, sdim,sim 30 pin,sim 72pin ,or dimm
hope this helps
9/2/2011 7:39:32 AM • Intel D845GLLY... • Answered on Sep 02, 2011
Motherbord d845glly no audio device
You can download the motherboardaudio and device drivers from Intel WEB site. Select your model motherboard/device, andmake sure you select the Windows XP or Vista version of the drivers that
matches your Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
9/1/2011 2:35:08 AM • Intel D845GLLY... • Answered on Sep 01, 2011
I am lost my sound driver and i am know my mother
Hi there, Download this software and install it. When running it it should identify the driver for your soundcard and assist you in downloading it. http://www.zhangduo.com/udi.html
regards,
7/23/2011 6:12:35 AM • Intel D845GLLY... • Answered on Jul 23, 2011
I'm unable to recover the
http://majorgeeks.com/BIOS_Patcher_d3965.html
Find and fix errors in your system BIOS BIOS Patcher can find and fix errors in your system BIOS (only AWARD BIOS for now) and also it can add or open new features, i.e. some features that your BIOS has but they are closed by manufacturer of your motherboard. It scans rom file. If it finds any known errors it fixes the errors. If it finds any closed features it opens it. hope this helps also http://majorgeeks.com/downloads25.html here you will find a vast array of bios tools
6/3/2011 7:47:08 PM • Intel D845GLLY... • Answered on Jun 03, 2011
3answers
I want free download for
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Chipsets&ProductLine=Desktop+Chipsets&ProductProduct=Intel%C2%AE+845+Chipset+Family&ProdId=757&LineId=127&FamilyId=40
Download the required driver from this URL, ITS free
6/1/2011 12:45:55 PM • Intel D845GLLY... • Answered on Jun 01, 2011
Beep after every 10-15 seconds,
Depending on the beeps, it can mean different things.
The most common error is because your RAM sticks are loose. If you are proficient in operating PC hardware, open your case, remove the RAM sticks, brush the contacts slightly for dust, and put them back in, lodging them properly.
If you aren't sure of what to do, ask someone whose down this before. You dont want to pull out the wrong components.
3/13/2011 7:35:41 AM • Intel D845GLLY... • Answered on Mar 13, 2011
MY MOTHER BOARD NMBER
Are you sure you downloaded it for your operating system? Try running the program as administrator. Try playing with the compatability options also
2/28/2011 9:11:43 PM • Intel D845GLLY... • Answered on Feb 28, 2011
Having installed window xp. sound
Insall an audio driver. click here to download all drivers
2/15/2011 1:32:26 PM • Intel D845GLLY... • Answered on Feb 15, 2011
2answers
My motherboard is that of
Do the following:
  • Control Panel
  • System
  • Hardware
  • Device Manager
  • Look for hardware listed under unknown, your system most likely tried to load the audio driver and couldn't find it at the initial software install of XP
  • Uninstall , Reboot your system, your system will try and reload the driver...point it to the correct file location or install manually
2/11/2011 2:31:47 PM • Intel D845GLLY... • Answered on Feb 11, 2011
Pls assist me in installing
Use the software paretologic driver cure if you cannot manage th drivers anyway
1/22/2011 1:40:38 PM • Intel D845GLLY... • Answered on Jan 22, 2011
I am unable to find
Try using the FREE Intel Driver Update Utility from Intel, a "trusted" source.
From Intel:
"The IntelĀ® Driver Update Utility keeps your system up-to-date. It detects which driver updates are relevant to your computer, and then helps you install them quickly and easily."
http://www.intel.com/support/detect.htm
Here's a direct link to your motherboards support section at Intel dot com
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d845glly?wapkw=%28Intel+Desktop+Board+D845GLLY%29
Oh, and don't forget to back your drivers once everything is running crisp and clean again. I use "Driver Max". It's also free and easy to use. Good luck friend!
1/11/2011 7:21:05 PM • Intel D845GLLY... • Answered on Jan 11, 2011
Intel D845GLLY Motherboard Logo
112 questions posted
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
want free download
  • Computers & Internet
