20 Most Recent
3Com Wireless LAN Access Point 7250 802.11g/b (3crwe725075a-uk) Questions & Answers
I dont know how to get internet on my ds lite
Nintendo? You have to have a WEP key...and if your wireless encryption is not set up with a WEP key, if it has a WPA or a WPA-2 key, it won't work. You have to change the encryption on your wireless (either router or modem, whichever you are using) ...open a browser and type 192.168.1.1 in the address bar, put in your password, and change the encryption type to WEP...then put the settings in the DS.
3com 3crwdr100a-72 how do I reset the router
For 3com type of routers, you must connect firstly to 3com setup, By:
First: open your browser and type 192.168.1.1
Second: you will find adapter setting and reset it, it all depends upon your router's software.
Third: the easiest way is to reset it from the small button in the back of your router.
I have AVI Video and it only plays sound
Ok it is may be do you to system is old needs up to date , so that the video may not have downloaded completely from the source web portal. The media player present in your handset is outdated.
Db9 rj45 pinout
Here is the standard pinout for a console port on a router to seriel port for computers
HI,
I have two 3com
I don't know anything about these units, nor do I have time to source any docs for you, but maybe you can try connecting a PC directly to the port your patch panel is connecting the the switch from, you can at least see if that port is working.
My next and only other suggestion is to invest in a "LAN cable tester". In my area, you can find cheap ones for U$20.
The tester will allow you to check connectivity between any two ports, and allows you to test both patch links and individual CAT5/6 cables.
Facebook recovery
notify the police dept / person handling the case and let them know about the face book information
