20 Most Recent Intel Desktop Board D815EEA2 Universal (BOXD815EEA2LU) Motherboard Questions & Answers
Replace battery and still cannot solve the date and time problem?
you might have to install another cmos battery the one you have might be bador you might have to change it to 24 hr time then revert it back a few times for the computer to realise the change hope this helps
9/27/2012 5:18:01 AM • Intel Desktop... • Answered on Sep 27, 2012
D815EEA2 - No Display But
Try shutdown computer using switch on tower. Restart in "safe mode". Window will pop up and click on "what is system restore", click on that. Another window will pop up, scroll down to "start safe mode", This will take a minute or two. A window will come up and click start or ok. The system will restore back, shut down and restart. Hope this helps.
3/22/2011 2:21:41 PM • Intel Desktop... • Answered on Mar 22, 2011
Ethernet driver not installed i
Go here.
2/21/2011 11:34:05 AM • Intel Desktop... • Answered on Feb 21, 2011
I have inteld815 board that was not working
it does not not starts when power button is pressed
tell me me the correct configuration of power button cabels
1/6/2011 7:42:40 AM • Intel Desktop... • Answered on Jan 06, 2011
My computer is able to boot but does not show on
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ? hope this helps
12/15/2010 9:53:22 PM • Intel Desktop... • Answered on Dec 15, 2010
I need intel d815eea2 audio
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
12/14/2010 11:20:08 AM • Intel Desktop... • Answered on Dec 14, 2010
2answers
Hi, i have an "universal
universal box is powered via USB port which is normally about 5v... I would recommend you first check the USB cable you are using, try to also check your USB port or change to a different one. Do you get any LED on the box once connected. do you get and USB to serial device listed under my devices one unit is connected. kindly post back with all this info so that i may help you further.
Regards
10/11/2010 2:30:13 PM • Intel Desktop... • Answered on Oct 11, 2010
I m using intel pentum iii computer with 30
Hi Good day!! yes you can extend it as long as it is a IDE Hard disk..
10/8/2010 2:19:36 AM • Intel Desktop... • Answered on Oct 08, 2010
How can i attach a USB2 device or enhance Data
First forget about speed if u have one of the cheap Chinese flash.
Try to update the usb drivers.
6/14/2010 12:50:04 AM • Intel Desktop... • Answered on Jun 14, 2010
Motherboard layout
JUST TIGGER FRONT PANNEL PIN
3/23/2010 12:43:40 PM • Intel Desktop... • Answered on Mar 23, 2010
Intel Desktop Board D815EEA2 boot problem
Hi and welcome to Fixya!
this means that the BIOS is corrupt ..
Thanks for using FixYa!
7/18/2009 9:05:10 AM • Intel Desktop... • Answered on Jul 18, 2009
POWER LED ON BOARD SHOWS THAT IT IS ON BUT SYSTEM DOES NOT BOOTS
Hi...
If that problem is happen check the monitor cable if it is correctly plug to the motherboard, if your motherboard have video card attach try to remove the video card, if the same things happen thee problem is the processor, you need to check the processor, remove it and clean then put a thermal paste so that the heat from processor will absorb by the heatsink, and be sure that the heatsink fan it working to prevent the heat.
Good luck !!!
Regards
PCmania
7/10/2009 11:01:19 AM • Intel Desktop... • Answered on Jul 10, 2009
I have an old board and want a manual (hopefully free)
You can download a manual for your board here, if that is what you need
4/11/2009 3:17:34 PM • Intel Desktop... • Answered on Apr 11, 2009
Intel d815/eea2 powers up but does not boot
hi im josh in cebu phils. if it turns on but not boot. the problem is no set boot sector is selected. friend try to enter bios set up and then go to boot menu. then select hard drive to boot first.then save the changes then restart the pc. if nothing improves open your pc check the ide or sata cable if it is ok.no cut not losen.try to tighten firmly first then turn on your pc. if it doesnt work the same try to change the ide/sata cable and dont forget to give power supply on your hard disk.ok. good luck
2/21/2009 4:50:08 AM • Intel Desktop... • Answered on Feb 21, 2009
REBOOT PROBLEM BY CHANGING OF PROCESSOR
Try to remove the battery so it reset the bios and then power it up.
1/26/2009 1:55:29 PM • Intel Desktop... • Answered on Jan 26, 2009
2answers
DATE & TIME changes automaically
For starters, thanks for the good description of your system!
If you feel up to it, turn off the computer and open its case, somewher on the motherboard you will find what looks like a watch battery, you may want to start with replacing that battery, - take it out and go to your local walmart or general store and find the same model battery, this should help with the computer loosing time and settings, also if the system is rebooting while starting up I would first take a look at the memory in the computer. Has more memory sticks ever been added to the system, if so you may have two or more memory sticks that are not play well with each other, or you may just have a bad stick of ram. I would test this thory by replacing the RAM sticks or try booting by just using 1 stick of ram and see if the problem still occurrs.
Hope this helps.
11/14/2008 4:19:10 PM • Intel Desktop... • Answered on Nov 14, 2008
Manuel
hello there!
here's the motherboard's driver download link for windows xp
Intel Support
i can only provide you with the link to where the drivers are located.
8/7/2008 7:35:24 PM • Intel Desktop... • Answered on Aug 07, 2008
I forget my password of Intel Atom N455 Windows 7, hw to open my notbook to change new password n continue my work in notbook?
You can reset it through the HP recovery manager. First, turn off your laptop and restart it while pressing the F11 key. Then, select System Recovery, and follow the on-screen instructions to reset your HP laptop password. After that you will be able to log into your laptop again. This is one Answer But you will find various ways. Google Forgot windows 7 password on my notebook & you'll be surprised what appears. YouTube also. Hope this helps
3/14/2024 3:15:19 PM • Intel Computers... • Answered on Mar 14, 2024
How long does the Intel i7-930 processor expected to last?
The best way to prolong life of a computer is to blow out dust from the case and cooling fins and power supply regularly, at least every year. That prevents overheating - a primary cause of component failure. Do not overclock. Do periodic full disk backups and intermediate new file ones. Leapfrog between two external disks. They are cheap. Protect them from fire. Laptops - same story,, do not block cooling holes by putting on a blanket while lounging. And turn off machine before blowing out dust. Do not use full PSI compressor air! maybe 20 PSI...
11/17/2023 5:55:13 PM • Intel Computers... • Answered on Nov 17, 2023
Intel Desktop Board D815EEA2 Universal (BOXD815EEA2LU) Motherboard Logo
22 questions posted
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
m using intel pentum iii computer 30
  • Computers & Internet
