20 Most Recent
Intel BIOSTAR Mainboard Support processor U8668D-A34 VER: 7.6 (BIOSTARU8668DA34VER76) Motherboard Questions & Answers
Nh82801gb drivers
http://download-drivers-free.com/free-intel-nh82801gb-driver-download/
My moher board u8668-d 7.6
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers if you don
I need the vga deiver
you can buy it from shop or other wise you can download it as torrent."http://torrentz.eu/search?f=vga+driver+for+I8400GV-P"
Sir my pc problam is
Test your PSU or replace it if your power supply units fan
is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including
electrical extensions,IDE,SATA
the leads from your
((motherboard to your hard drive)) make sure they have a secure connection
and are not faulty or just replace them they could be faulty
make sure all leads that
are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
and are not faulty even the electrical extensions or just replace them they could
be faulty a computer
needs its connections to continue its cycle and have an end so any faulty leads
will end up with a computer error if
this fails to fix the problem
another
possible reason could be a memory dump you might be running to many programs at
the one time placing to much strain on the CPU also you might not have enough
RAM random access memory to check what is running when your computer is running
scroll to the bottom toolbar right click select task manager applications and
processes if you see something you dont need running select end now to check
how much ram you have click start right click on my computer select properties
you will see all of your computers details another way to check
how much RAM you have click start all programs accessories system tools system
imformation all of your computers imformation will be there
try uninstalling a few unnecessary programs then click start run
type cmd then type chkdsk/r/f which will scan for and attempt to fix
any bad sectors and automatically fix any corrupt files on your hard drive this
will schedule on a restart don
Driver main U8668D
Go thru the below Link.
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=245
I need a audio-sound driver
Hi
looking for audio driver based on your motherboard model
click the link below to download the driver
DOWNLOAD
Dell(intel motherboard High Audio Defination
control panel administrive tools computer management device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s
to do this right click on the ? x ! select reinstall driver
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dell(intel motherboard NH82801GB)power showing
Hey there,
if you have another motherboard test the cpu there.
if you don't, then just do this with the ram, take all the ram out, and power on, it should beep or complain, let it for a moment, turn off unplug or switch off at the wall, install one of the memory modules back in and turn on.
How about the video card or is it build in to the board?
also does the powersupply have a green led on its back, is that FLASHING when you try to turn on? if so, the powersupply is probably bad, it should be steady green.
I dont have an audio
YOU HAVE TO INSTALL THE AUDIO DRIVER THAT COME WITH YOUR MOTHERBOARD CD OR DOWNLOAD FROM SOFTPEDIA.
Main boad driver for 18400 GV-P
i think your motherboard is ECS, you can go to the ECS website, the after that you just click the motherboard, then you just type the model of your motherboard, if you can see now the model, just click the driver, then chose the US then you can download now your motherboard driver
