20 Most Recent Intel D845GBV (BOXD845GBVL) Motherboard Questions & Answers
I have 266 mhz 256MB
hlo hyn you should get RAM 200/266 MHz of 512mb or 1Gb
below are the specifications your motherboard can support.
  • Two DIMM sockets supporting 2.5V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
for more info click this link http://www.intel.com/support/motherboards/desktop/d845gbv/sb/cs-012820.htm
8/18/2011 12:28:41 PM • Intel D845GBV... • Answered on Aug 18, 2011
After installing the xp operating
This is Intel's link for your board.
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d845gbv
You can get your download here if it's available. There is an audio troubleshooting system area you can check out however, if you have the IDT or ADI sound on your system, you may not have any luck with drivers as the companies have folded. If you have Realtek sound, you can try here:
http://www.realtek.com.tw/downloads/
Go into your device manager and click on the box next to "sound, audio and game controllers" and you will see your devices. If you see "IDT(sigmatel), or ADI(soundmax)" in your list. You may want to consider an upgrade to a sound or graphics card. The Radeon HD cards can give you graphics and sound using ATI's DVI adaptor.
Dave
7/1/2011 12:14:38 PM • Intel D845GBV... • Answered on Jul 01, 2011
Intel845 mb 3ghz processor no
Just check the motherboard manual because I think you just got problem in hardware compatibility.Remember if your processor and memory are not compatible the first thing that might happen is your process will be damage. But since you it start only when you install antivirus, you have to reformat your disk, to solved the problem.
5/2/2011 12:37:22 PM • Intel D845GBV... • Answered on May 02, 2011
No sound card
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps you might have to get a portable usb sound card if you mean dont have a sound card installed
4/2/2011 7:47:00 PM • Intel D845GBV... • Answered on Apr 02, 2011
Self having the following configuration
Power down and disconnect AC power from your PC. Remove the AGP card and DIMM again and use some "canned air" or dusting spray to get any dust off the contacts on your motherboard and your memory and AGP card. Wiping the AGP card contacts with some isopropyl alcohol (also known as IPA or "rubbing alcohol") and a clean, lint-free cloth can also help. When everything is dry, put your card and memory back in and try powering up again.
3/21/2011 10:01:10 AM • Intel D845GBV... • Answered on Mar 21, 2011
CMOS time not getting set even after changing the
try reset the bios with jumpers
onthis page you can download the manual:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=15322&ProdId=825&lang=eng
name of the file is:
D845RG_D845BV_ProductGuide_English.pdf
2/21/2011 4:29:12 PM • Intel D845GBV... • Answered on Feb 21, 2011
NO AUDIO ON MY PC D845GBV
Hi, Thanks for using fixya.
Check:
speakers Pluged in? If powered speakers is the power light on the main speaker. In device manager is there any yellow ! or ?. Here is a site for your driver download:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=5577&lang=eng
Terry
If you have any further questions regarding this matter feel free to post a comment or if you are satisfied with my answer, please give it a rating for this is the reason I do this work.
2/20/2011 11:17:11 AM • Intel D845GBV... • Answered on Feb 20, 2011
4answers
Intel d845 gvfn display problem.
sir i have a problemmy mother board intell d845 epi/d845gvsr my mother board is cannot desplayed or display is not come but if i remove rame the mother board is give error beaps if i attach ram board is not displayed
2/11/2011 5:38:53 AM • Intel D845GBV... • Answered on Feb 11, 2011
No video output nothing on the screen
is this on a laptop or desktop system?
can you see the screen when you turn the system on? if so go into the bios and change
see manual here pdf format page 53
http://www.fixya.com/support/p316665-intel_d845gbv_boxd845gbvl_motherboard/manual-10616/page-7#
1/18/2011 10:49:15 AM • Intel D845GBV... • Answered on Jan 18, 2011
I have a Intel D845GBV
You can only upgrade as high as your components will allow. If you get a brand new motherboard, you'll also need to get the appropriate RAM, and CPU style. When you're looking into buying a new motherboard, especially to replace a single core motherboard, you usually have to upgrade RAM, CPU and possibly video card, if you're using an older AGP style video socket - so make sure that if you DO upgrade your board, you either keep it within the limits of your components, or upgrade the appropriate pieces along with the motherboard.
11/21/2010 12:19:27 AM • Intel D845GBV... • Answered on Nov 21, 2010
My desktop goes on black
BLACK?
Pleae give us more DETAiLS!
11/6/2010 4:48:29 PM • Intel D845GBV... • Answered on Nov 06, 2010
3answers
D845GBV Motherboard Problem will lan card support
yes the board will support a PCI lan card. Yuo can upgrade your ram to 2X 256mb or 1x 512mb pc2100 333mhz
9/7/2010 2:22:14 PM • Intel D845GBV... • Answered on Sep 07, 2010
Plzzz tell me from where i can install audio drive...
Open the link provided; http://downloadcenter.intel.com/download.aspx?url=/12170/eng/wdm3516b_Cadenza.exe&DwnldId=12170&lang=eng
Create a folder on you're desktop and name it Audio. Save the file into the audio folder.
Click on: Audio: AC 97 ADI* To download.
Was this helpful.
Mike
5/21/2010 10:13:17 PM • Intel D845GBV... • Answered on May 21, 2010
D845GBV (BOXD845GBVL) Motherboard: M3S with product code M363S. I am formatting my la...
download it from intel.com
5/19/2010 10:39:40 PM • Intel D845GBV... • Answered on May 19, 2010
2answers
Windows 7 (or compatible) drivers for Intel D845GBV
Hello
Click Here to download the drivers for D845GBV
Please let me know if you have any further questions or concerns.
Thanks.
5/4/2010 6:35:01 PM • Intel D845GBV... • Answered on May 04, 2010
7answers
INtel D845 GVFN Board VGA
Nisar Ahmad, your Intel board D845GBV noes not support the windows Vista platform any version.
Please click the link below which will load Intel's web site for the,
D845GBV. You will need to pick your operating system from the download window & you'll there are not drivers for Vista.
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=825&lang=eng
Sorry, if you feel you need to complain send your email to Intel.
Mike
3/11/2010 11:51:35 AM • Intel D845GBV... • Answered on Mar 11, 2010
D 845gbv original m/b. tried to fix 250gb hdd
The converter is more than likely the problem, I've had it myself many times.
2/15/2010 7:44:26 AM • Intel D845GBV... • Answered on Feb 15, 2010
Intel D845GBV (BOXD845GBVL) Motherboard Logo
73 questions posted
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
no video output nothing screen
  • Computers & Internet
