20 Most Recent Intel Desktop Board D845EBG2 Motherboard Questions & Answers
Type of video card for D845EBG2
The Intel D845EBG2 motherboard supports AGP graphics cards.(Accelerated Graphics Port)It supports AGP graphics card's that are AGP 4X, and 1.5 Volt.(Supports AGP 2X also, but who cares)1) Good;http://www.newegg.com/Product/Product.aspx?Item=N82E1681416131880 Stream Processors.(Also; Read the reviews)What are stream processors? Nothing new. Just a new term for the same old graphics technology;"A stream processor is an ALU which is usually involved in handling SIMD instructions. ALU stands for Arithmetic Logic Unit, which in English means "number cruncher". It's the part of the chip that does the actual computation involved in processing data. Nearly every chip around today no matter if its in your video card or your coffee maker has at least one ALU. "SIMD instruction" means that it crunches a group or "stream" of numbers all at once rather than one at a time. For the RV740, the number you hear is 640 "stream processors" because each of the eight shader cores has sixteen execution units and each of those has five ALUs: 8 x 16 x 5 = 640."From MIME,http://forums.amd.com/forum/messageview.cfm?catid=12&threadid=113850(I like MIME's explanation)2) Better;http://www.newegg.com/Product/Product.aspx?Item=N82E16814161337320 Stream Processors(Also; Read the reviews)More added info on graphics technology;A) http://computer.howstuffworks.com/graphics-card.htmB) http://computer.howstuffworks.com/3dgraphics.htmC) http://computer.howstuffworks.com/agp.htmRegards,joecoolvette
6/29/2012 8:36:01 AM • Intel Desktop... • Answered on Jun 29, 2012
When flashing bios it displays internal program error
this error could be caused by a number of things would take a lot to describeclick start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might be able work your way through the problem if you need more help post a reply with the error details hope it helps
4/25/2012 2:59:30 AM • Intel Desktop... • Answered on Apr 25, 2012
2answers
Where do the wire leads
Hi. This link should help you out.
http://www.intel.com/support/motherboards/desktop/d845ebg2/sb/CS-008638.htm
Click the D845EPT2_D845EBG2_TechProdSpec link. You will need a PDF reader installed to view the manual. Goto page 72 of the manual, all the information you need is there. Hope this helps you out.
2/18/2011 11:47:30 PM • Intel Desktop... • Answered on Feb 18, 2011
I WANT TO DOWNLOAD VGA DRIVER FOR MY INTEL 845 GL/GV AS I LOST MO
You can get them from here.
7/27/2010 5:12:20 PM • Intel Desktop... • Answered on Jul 27, 2010
Sound download
please install pc inspector
6/5/2010 2:18:37 PM • Intel Desktop... • Answered on Jun 05, 2010
The board will not boot...
This seems to be a problem with your motherboard as I can see that's the oldest parts that yu haven't tried changing yet, that's fine for the mean time you can also do this as the last step for the this troubleshooting and isolation before changing the motherboard. You can do the jumper on your motherboard that is by putting the jumper setting of your board since you have a old motherboard I suggest you download the user manual for it so you can see the procedure to do the jumper settings on it and if still not working after that board needs replacement already......
11/9/2009 1:06:41 AM • Intel Desktop... • Answered on Nov 09, 2009
2answers
Hi i have intel desktop board d845ebg2......when
Write zeros to the HDD using the HDD manufacturer's software, and then partition it, format it, and install your OS
11/7/2009 5:53:57 AM • Intel Desktop... • Answered on Nov 07, 2009
Intel d845ebg2 cannot setup windows pls help
You probably added the wrong Ram memory. Some if those 512 memory, are not suitable for windows XP and UP.Try removing the 512 Ram module and see what happens.
Good luck.
11/7/2009 3:23:05 AM • Intel Desktop... • Answered on Nov 07, 2009
Driver
You can download the drivers from the following website
http://tinyurl.com/ownzz5
Thanks
proton
5/27/2009 3:30:21 AM • Intel Desktop... • Answered on May 27, 2009
I need intel DESKTOP motherboard model D845EBG2
Here is the link, the bios update is at the top of the page.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=823&OSFullName=All+Operating+Systems&lang=eng&strOSs=All&submit=Go%21
Good luck, and make sure you have a good power source and do not interrupt the flashing of the bios. If it stops in the middle of flashing, it will brick your motherboard and make it probably not fixable.
4/11/2009 11:53:03 PM • Intel Desktop... • Answered on Apr 11, 2009
Will not fully boot
sir good day i had the same problem and what i did is i press f8 again and again upon start up until the options shows you might try selecting last known better configuration, or go to safe mode, and run a restore point of your liking date, if this two didnt work another thing you could do is put your operating system disk and reinstall it or repair it.. i hope this helps thank you and fixya..
12/22/2008 6:09:23 AM • Intel Desktop... • Answered on Dec 22, 2008
3answers
Need pin settings
Dear S_Proheartdt,
you can download the complete manual for this motherboard from this site, it will really helpful to you:
http://www.intel.com/support/motherboards/desktop/d845ebg2/sb/CS-008633.htm
Be Happy Always
Regards
12/3/2008 3:24:18 AM • Intel Desktop... • Answered on Dec 03, 2008
Sandrew
my disply is not working
6/21/2008 4:59:03 AM • Intel Desktop... • Answered on Jun 21, 2008
I forget my password of Intel Atom N455 Windows 7, hw to open my notbook to change new password n continue my work in notbook?
You can reset it through the HP recovery manager. First, turn off your laptop and restart it while pressing the F11 key. Then, select System Recovery, and follow the on-screen instructions to reset your HP laptop password. After that you will be able to log into your laptop again. This is one Answer But you will find various ways. Google Forgot windows 7 password on my notebook & you'll be surprised what appears. YouTube also. Hope this helps
3/14/2024 3:15:19 PM • Intel Computers... • Answered on Mar 14, 2024
How long does the Intel i7-930 processor expected to last?
The best way to prolong life of a computer is to blow out dust from the case and cooling fins and power supply regularly, at least every year. That prevents overheating - a primary cause of component failure. Do not overclock. Do periodic full disk backups and intermediate new file ones. Leapfrog between two external disks. They are cheap. Protect them from fire. Laptops - same story,, do not block cooling holes by putting on a blanket while lounging. And turn off machine before blowing out dust. Do not use full PSI compressor air! maybe 20 PSI...
11/17/2023 5:55:13 PM • Intel Computers... • Answered on Nov 17, 2023
Reading mac hard drive on intel machine
MAC uses RAW/APFS etc and Intel uses full format DOS based. Not compatible.
11/3/2023 7:04:12 AM • Intel Computers... • Answered on Nov 03, 2023
Intel D865GVHZ Motherboard won't boot into anything but will turn on
If your Intel D865GVHZ motherboard is not booting and you've tried replacing the CMOS battery, resetting it, reseating RAM, and changing the PSU, it may indicate a more serious hardware issue. You should consider checking the following: 1. Check the monitor: Ensure that the monitor is functioning correctly by trying it with another computer. 2. Check the connections: Verify that all cables, including the power and video cables, are securely connected. 3. Inspect for hardware failures: Check for any visible signs of hardware damage or loose components on the motherboard. 4. Test with minimal hardware: Disconnect all unnecessary peripherals (e.g., external drives, graphics cards) and leave only the essentials connected (CPU, RAM, power, and monitor) to rule out any conflicts or faulty hardware. 5. Try a different RAM: If possible, test with different RAM modules to rule out faulty memory. 6. Listen for beep codes: If your motherboard has a speaker, listen for any beep codes during startup, as they can provide clues about the issue. 7. Inspect the CPU: Check the CPU for any damage or bent pins, and ensure it's seated correctly. If none of these steps resolve the issue, it's possible that your motherboard or other critical components may have failed, and you may need to consider a replacement or professional diagnostics to pinpoint the exact problem.
9/7/2023 8:43:01 PM • Intel Computers... • Answered on Sep 07, 2023
Intel Desktop Board D845EBG2 Motherboard Logo
Popular Tags
21 questions posted
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
want download vga driver intel 845 gl gv
  • Computers & Internet
