20 Most Recent BellSouth Auto multi-channels 2-way radio walkie talkie t-388 2pcs Questions & Answers
Where can I get a manual?
do a web search include the make and model of the units and add various words such as instructions...manua....guide etc several results will be thrown up, you will have to trawl through them
7/15/2015 1:38:54 AM • BellSouth Auto... • Answered on Jul 15, 2015
I need a manual
http://www.upzone.com/downloads/summary/7-manual/1254-the-manual-of-walkie-talkie-atomatic-battery-save-walkie-talkie-88006651.html
6/12/2014 1:41:06 PM • BellSouth Auto... • Answered on Jun 12, 2014
Ny bellsouth 1010 walkie talkie are locked, there is A sign of A key in the display And I cannot remove it
The key shown on the display is a "Button Lock". Press and hold the LAMP+ button until the key goes away. Manuals for the 1010 are still available from WOOIL telcom
1/10/2022 11:14:45 PM • BellSouth Radio... • Answered on Jan 10, 2022
2answers
I need a charger for bellsouth 2210 walkie talkie
sorry we do not sell parts here.
3/28/2019 9:30:54 PM • BellSouth Radio... • Answered on Mar 28, 2019
Is the two way radio easily fixed, suspect mic, or is it garbage?
If you can do minor soldering, you may be able to fix the radio. They have no parts available, so they are considered "junk" when they break. But if you do the following, you may be able to repair it: open radio, unscrew the housing and pull it apart. Take the circuit board and look for corrosion, it often looks greenish or white. If the radio has a lot, there is water damage. You may still be able to fix it. You've gone this far! Use a Q Tip dipped in rubbing alcohol and remove as much corrosion as you can. Let it dry. Take your soldering gun and lightly resolder each spot on the circuit board. Touch the tip, as soon as the solder turns liquid, remove it! I have fixedhundreds of radios and cell phones by doing this. But it may not work. It just takes your labor! Good luck!
3/28/2019 8:09:45 PM • BellSouth Radio... • Answered on Mar 28, 2019
My Bellsouth 1010 Wilkie talkies power up fine. Can blow and this transmits fine but talking does not transmit. What am I doing wrong?? I am on the same channel with both.
Please try to have the 2 receivers at least 20-30 ft apart. You may be overloading them if you are too close.
10/8/2018 2:45:51 PM • BellSouth Radio... • Answered on Oct 08, 2018
I am looking for a manual for the BellSouth 1050 walkie talkie.
To get the user manual for your 1050s, go here: https://fccid.io/O631050LD02/User-Manual/users-manual-234549 Good luck.
1/26/2018 6:06:45 AM • BellSouth Radio... • Answered on Jan 26, 2018
I have a set of Bellsouth walkie talkies and on one, all though I can change the volume settings, I can not get it loud enough to hear unless i put it tight to my ear
Very likely a blown speaker. Those speakers do not stand up to weather well and may have gotten wet. The only solution is replacement. Since you cannot buy a speaker, you would need to buy another radio and use it for parts. Better yet, buy a working radio and use you old one for parts.
6/22/2017 6:27:19 PM • BellSouth Radio... • Answered on Jun 22, 2017
I have 2 bellsouth 2250 walkie talkies and have set them both to the same channel and subchannel, but cannot get them to communicate. What am I doing wrong?
Nothing. You have already said channel, which is frequency and sub channel, which is called a lot of things. You are 99% ahead! My best guess: turn them Off and On. Then check the channel and subchannel again. One of the radios did not save the information or lock it into the memory. The On/Off cycle may save it and they will work! Let's cross our fingers. But do not hesitate to reprogram them as many as 3-5 times and look for a SAVE feature in the manual. Best of luck!
2/13/2017 4:07:12 AM • BellSouth Radio... • Answered on Feb 13, 2017
0answers
BellSouth Auto multi-channels 2-way radio walkie talkie t-388  2pcs Logo
4 questions posted
Top BellSouth Radio Communications Experts
Are you a BellSouth Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • BellSouth Radio Communications
Most Popular Question
looking manual t 388 instructions
  • Radio Communications
