20 Most Recent
BMW 2004 530i Radio Questions & Answers
Eonon d5150 screen problem
I Just bout an r32 mk5 golf 4motion and it has eonon unit. The touch screen not working I can not move up or down the icons to turn blue tooth on. Or anything cant select between USB stick and sd card and not showing any maps the touchscreen not in any operation at all. Has anyone had this issue
97 BMW 528i cuts off when I step on the gas
Check your fuel pressure at idle and when at higher rpm while not driving. You can usually borrow a pressure tester from an auto supply store. The place to test it will be on the fuel injection rail on top of the intake manifold. I would buy a Haines manual too.
Secuity codes for a BMW radio
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio. The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your BMW service centre and get them to enter this code for you.
I found water in around amp in battery compartment
you may have to take the amp apart and clean any corrosion off inside of the amp. if the corrosion ate any of the leads of components or any traces, you may have to replace the amp. this is assuming it is the factory amp you are talking about.
Bmw
Be more specific with your details.
I have a problem with my 2000 bmw 528i. I
very interresting. could be that one of the cables short to ground due to damaged insulation. there is no logic that a fuse is blown without shortage or over currency. i dont think it will cause any problem to remove hole unnecessary cables.
please feel free to contact me here under your topic if any further assistance is needed
regards
