20 Most Recent Intel (P42000400512SK478) Pentium 4, 2 GHz Processor Questions & Answers
3answers
Does Intel Pentium 4, 2 GHz Processor support 2GB
Type of RAM supported has nothing to do with the processor make & type in most cases. It is more important to verify that the motherboard supports this kind of RAM.
In general, most motherboards supporting the Intel Pentium 4 2.0 GHz processor support also DDR1 RAM.
5/22/2022 3:48:44 PM • Intel... • Answered on May 22, 2022
P4 2ghz prosesor support to
1/18/2011 2:43:13 AM • Intel... • Answered on Jan 18, 2011
Hello, i have one socket ga478b
pentium 4 2ghz socket 478, either a northwood or prescott type of processor, visit this link for your reference when buying a processor for your motherboard,
http://www.cpu-world.com/Sockets/Socket%20478%20(mPGA478B).html
9/27/2010 8:06:10 AM • Intel... • Answered on Sep 27, 2010
5answers
My pc always hang...
If removing the black powder was damaging to the processor then your system wouldn't start at all.
If I am interpreting this correctly, your PC is only hanging when you restart. It sounds like what you did was pull the heatsink and fan off of the processor and you wiped away that black powder/smudge junk that OEM vendors such as HP use as thermal material between the heat sink and processor.
Some systems do that. It's to be expected. It COULD be caused by a temperature sensor detecting higher temps, though. (Although that's not likely if it's still starting when you shut it down completely and then start it back up.)
The first thing you want to do is re-seat the CPU in it's socket. I don't know what kind of CPU you have so I don't know what kind of socket it is. Be careful in doing so and if you don't know how to open and close the socket then do a little research online for some instructions; or come back here and tell me what kind of CPU you have.
After re-seating the CPU correctly, you want to be sure to clean the die of the CPU with some kind of solvent (such as alcohol) to get rid of any grease or random chemical build-ups. If there is still sticky residue on the CPU from the thermal material, you can normally get rid of that using a bit of WD-40 on a cloth. (DO NOT APPLY ANY CHEMICALS DIRECTLY TO THE DIE OF THE CPU. PUT IT ON A CLOTH FIRST.) If you use WD-40 to clean the CPU die, use alcohol to clean up the WD-40 afterwards.
Do the same to the bottom of the heatsink. Apply WD-40 directly to the bottom of the heatsink if you like. It tends to eat away all of the sticky junk well enough that you can just scrap it off. Clean the surface with alcohol afterwards.
Get yourself some thermal paste from either Radio Shack or an online store. (Radio Shack is currently selling Arctic Silver thermal paste. Good stuff.) Apply just a SMALL DAB of it to the die of the processor and spread it around until you have a nice, thin and even layer of it. (You don't need a ton of it on there.)
OPTIONAL STEP FOR BETTER RESULTS:
If the heatsink is rough on the bottom of it, you can buy sandpaper and sand the bottom of it flat and smooth on top of a flat, glass panel. Make sure to give it a good, smooth finish with a fine sandpaper. This will give it a good, flat surface to make contact with the CPU and will help thermal transfer a great deal. Clean the heatsink and apply it to the top of the CPU carefully.
MAKE SURE THAT THE HEATSINK IS NOT FACING THE WRONG DIRECTION WHEN YOU PLACE THE HEATSINK ON THE CPU AGAIN. If you do, it may actually sit on the socket that the CPU is in rather than on top of the CPU itself. If you turn it on like that, you may burn the processor.
Lock the heatsink down onto the processor as normal.
That junk that OEM vendors put on CPU's should be banned. It's better than nothing...but not by much. They tend to use junk heatsinks and even worse thermal transfer material.
I doubt you damaged your CPU by taking off a little bit of the thermal material like that. However I'm not saying that it's not possible, either. It most likely just got a little bit hot afterwards if anything.
At the very least, clean the surface of the heatsink and the CPU and put some thermal paste there between them. Things should run fine after that. But if your system continues to hang on a restart, then I wouldn't panic. Mine does that sometimes. No big deal. I just shut it down instead of restarting it and turn it back on.
Either way... If you follow these instructions and have a better cooling situation, you're going to experience a bit more stability and possibly better performance with your system.
Let me know how it goes.
Cyryl
6/30/2010 3:39:47 AM • Intel... • Answered on Jun 30, 2010
yes it will support
6/22/2010 8:41:46 AM • Intel... • Answered on Jun 22, 2010
Lag lag
Have you tried to review the systems requirements for Windows 7? In case you don't, try to review this system requirements and see if your PC falls in. If not, then its the primary cause of the "lag" computer.
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
4/27/2010 7:25:28 AM • Intel... • Answered on Apr 27, 2010
6answers
Upgrade from Pentium 3 to Pentium 4
haw can upgrade pentium3 to pentium 4
8/12/2009 10:06:51 AM • Intel... • Answered on Aug 12, 2009
My Pentium 4 2.4 GHz processor is running at only
in the BIOS-setup, normally you can adapt the bus speed. as it's running at about 400mhz, i suppose it's set to auto. within the advanced system settings, you should be able to set the bus config to manual and then you can choose the appropriate bus speed below.
6/23/2009 1:25:38 PM • Intel... • Answered on Jun 23, 2009
2answers
Pentium 4 comptability with SD Ram
If you know what mother board you have you could check what RAM it can use.
All RAM is installed in the same way, but different types of RAM are keyed differently. That basically means that one type of RAM (for example SD RAM) will simply not fit into another type of RAM slot (for example a DDR RAM slot).
To install ram on a PC
Please note - do NOT touch the connector side of the RAM, handle it only by holding the side or top edge
1. check that you have the right type of RAM. do this by lining up the RAM above the RAM slot and making sure that the RAM is the same length as the RAM slot AND ALSO that the RAM's key (the little hole or notch in the RAM) lines up with the key in the RAM slot. Note there might be more than one key
2. open both clips of the RAM slot by pushing them down and out from the center of the RAM slot
3. gently insert the RAM into the RAM slot
4. check again that the RAM and the RAM slot's key's line up, if they do, firmly press down on the RAM on both corners until both clips automatically click shut on the RAM
That's it! :-)
-Magnon
2/22/2009 11:29:50 PM • Intel... • Answered on Feb 22, 2009
I can't format my system
You can't format windows while it is in use..use the windows installation disk to format and install the fresh copy of windows..
1/18/2009 6:19:51 AM • Intel... • Answered on Jan 18, 2009
CPU running temp
Generally you will see core temps around 50C with a stock fan and no overclocking, that is if you run fully loaded 100% cpu usage. But this is all highly dependent on what type of cooling you have. A program like GIMPS Prime 95 will test your processor. The max temp for most of the Pentium 4 series is 85C, but to know all the details we need to know which core you have. Wikipedia would help you determine which core you have, or you can download a program that will tell you.
http://en.wikipedia.org/wiki/Pentium_4
12/14/2008 5:37:40 PM • Intel... • Answered on Dec 14, 2008
2answers
Visual basic software
12/6/2008 1:27:12 PM • Intel... • Answered on Dec 06, 2008
2answers
P4 Pentium
The GA-8IE comes with the 845E chipset. The below link will provide a list of all the processors the board will support.
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1320
It appears that the fastest it will support is the P4 Prescott, Northwood, or Extreme @ 3.4GHz (800MHz FSB).
Hope this is the information you were looking for.
MO
8/11/2008 12:32:56 PM • Intel... • Answered on Aug 11, 2008
2answers
MY PC POWER iS NOT WORKING
if the computer does not come on when you press the power button, check all of your cables and make sure they are attached right, if they are, you could have a bad power supply aka "psu" you can purchace a power supply from any computer store for 30-100 bucks i would recommend at least a 300 watt power supply if you are using a desktop pc. you can also have it tested at most computer repair shops.
8/9/2008 11:47:25 AM • Intel... • Answered on Aug 09, 2008
I need freedownload for MB 845 GL Motherboard
try this one
click me
hope this helps
5/12/2008 7:42:39 AM • Intel... • Answered on May 12, 2008
I forgot my password for the administrator...
remove the dime battery form mother board
4/22/2008 2:49:28 AM • Intel... • Answered on Apr 22, 2008
Jittery,pausing and skipping video and audio
TRY TO INSTALL THE LATEST DRIVERS FOR YOUR VIDEO CARD, AND ALSO TRY DOWNLOADING AND INSTALLING THE KLITE MEGA CODEC PACK FROM HERE IF YOU ARE USING WINDOWS MEDIA PLAYER http://www.free-codecs.com/download/K_lite_codec_pack.htm
4/2/2008 9:50:09 AM • Intel... • Answered on Apr 02, 2008
3answers
Processor over heating
This is normal behavior. Fans normally only run when they are needed, and your computer has multiple temperature sensors that direct this behavior (they are primarily located on the CPU, which could explain why the fans all worked when you took the CPU out). You should only be concerned about the fans stopping if your computer is, indeed, overheating.
2/1/2008 11:49:38 AM • Intel... • Answered on Feb 01, 2008
2answers
Upgrading
To upgrade from pentium 3 to P4 you have to change alot of the hardware.
You need a NEW P4 Socket mPGA 475 Motherboard.
New DDR RAM
New 478 PIN Processor.
You can use the old CD rom and Hard drive and any other PCI card but You Need the Mentioned Hardware to Upgarde.
2/1/2008 11:37:03 AM • Intel... • Answered on Feb 01, 2008
Intel (P42000400512SK478) Pentium 4, 2 GHz Processor Logo
Popular Tags
34 questions posted
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
one socket ga478b
  • Computers & Internet
