20 Most Recent Intel CMI 8738 6-Channel 5.1 Surround Sound 3D PCI Sound Card (RETAIL BOX) - CM8738 Questions & Answers
The chipset name is CMI8738 from CMedia.
CMedia drivers for this chipset are here
http://www.cmedia.com.tw/EN/DownloadCenter_Detail/pserno-49.html
Intel CMI 8738... | Answered on Jul 27, 2014
http://download.cnet.com/realtek-high-definition-audio/3000-2120_4-10788600.html
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
SlimDrivers automatically updates PC drivers with real-time scanning and cloud technology. The first cloud-based utility for updating and maintaining drivers, SlimDrivers provides instant optimization of the interaction between a computer and its system components and periperhals, such as printers, graphic and sound cards, motherboards, USB ports, game controllers and other devices and hardware.
Intel CMI 8738... | Answered on Nov 04, 2011
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you dont have a disk with the drivers you will have to download them
http://www.boxdrivers.com
using this link you will be able select your drivers
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
Realtek AC'97 Drivers & Applications. The package includes: Driver/Application Setup Program; RtlRack for Win98/Me/2000/XP and AvRack for Win95/NT4; Realtek Sound Effect Manager. DirectX 8 is required to enable advanced features.
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html free sound drivers
Realtek HD audio driver package. The package includes: driver setup program, drivers for Vista 32-bitedition.
if these arent right you will find free sound drivers
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)but don't use numbers or / - also the download software finder under that there will be a list place a tick in the box of any one you want/need
hope this help you
Intel CMI 8738... | Answered on Sep 08, 2011
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
Intel CMI 8738... | Answered on May 08, 2011
check if it is plug properly and its in the right position.... turn on your speaker and the volume check it. . . see if the the speaker standby light is on...
thank you and have a nice day. . .
Intel CMI 8738... | Answered on May 02, 2011
http://download.cnet.com/C-Media-CMI8738-WDM-Driver-Windows-XP/3000-2120_4-10495782.html
1. Click link above.
2. Click "Download Now".
3. Save file to desktop.
4. When download is complete, doubleclick on the file you saved. Now it installs the driver.
Please vote if this helped.
Intel CMI 8738... | Answered on Mar 17, 2011
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Intel CMI 8738... | Answered on Feb 20, 2011
click start control panel sounds and audio,volume you can adjust the volume or
advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Intel CMI 8738... | Answered on Jan 06, 2011
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Intel CMI 8738... | Answered on Oct 25, 2010
Did you try reinstalling the drivers for the sound card?
Otherwise, be a bit more specific about the type of problem you have with it.
Intel CMI 8738... | Answered on Sep 08, 2010
just go to the below link, and download drivers detective, it will automatically detect drivers from internet, and you can hassel free install it.
note: you require WINRAR software to unpck archieve
http://www.megaupload.com/?d=5V355FUL
Intel CMI 8738... | Answered on Aug 14, 2010
You can download from here http://downloadnew.org/software/intex-cmi8738-drivers/
just Rate My Answer Please
Intel CMI 8738... | Answered on Aug 12, 2010
Computers & Internet Logo
50 questions posted
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
drivers
  • Computers & Internet
