20 Most Recent
Disney Mix Stick pink And Accessories Bundle Questions & Answers
How do I get music to down load onto Disney Mix
You just plug this device to the USB port.Open my computer, you'll find an icon with the name Disney Mix , double click this to open.
Now minimize this window, go the folder where your songs are .. select those songs,copy them and come back to disney MiX window and paste those songs.
Solution2:You right click the songs and click option send to -- and choose disney Mix option from the list.
If you want to download songs from the website, make sure you save it to Disney Mix.
If you need more help on this.Let me know !!
Thanks.
Como hago para registrame en hotmail ayudenme x fa
Welcome to fixya
I have a solution for this
Content
Vas a tener que registrar por una cuenta por gratis
Your pre-solution is located above. More information is available
in the comments
My name is Bruce
Mix Stick software
If you have XP just plugin the Mix Sticks. You'll see as an external USB mass storege and you could copy mp3 files on it
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
