20 Most Recent Pitco Frialator 35CS Deep Fryer Questions & Answers
Flames coming out of the flue
There is most likely oil/oil residue in the chimney.
4/5/2016 3:02:08 AM • Pitco Frialator... • Answered on Apr 05, 2016
2answers
Pilot light does not stay
Hi there.
Try cleaning the thermopile, it must be free of soot or any form of dirt. Ensure that the gas pressure is sufficient, all wiring connections are tight and the hi limit is good.
If all of these are okay and the pilot still wont stay lit, try replacing the thermopile.
For Owner's manual download that will help you in minor fryer troubleshooting and reference, visit http://www.pitco.com
Regards.
12/11/2015 5:01:11 PM • Pitco Frialator... • Answered on Dec 11, 2015
Pitco fryer pilot light wont stay lite
The thermocouple is bad or the pilot light is not adjusted to heat the thermocouple to the point where the safety shut off stays on.
1/3/2015 3:40:28 AM • Pitco Frialator... • Answered on Jan 03, 2015
0answers
Soot coming out of flu
Hi there. Soot coming out of the flue indicates poor flame quality and probably carbon or soot build up on fire tubes. Have a technician check the gas pressure and the fire tubes for verification and cleaning if needed. Regards.
12/4/2013 6:19:11 AM • Pitco Frialator... • Answered on Dec 04, 2013
Pilot light will not stay lit once pilot button is not depressed. Replaced thermopile already. Any suggestions? Also don't have milivolt detector. Thanks
Hi there. Check the wiring, loose wiring terminals can disrupt the current going to gas valve. Try also to connect jumper wire across the hi limit terminals, if this do the trick, replace the hi limit device before operating the fryer. Lastly, the gas valve may be defective. Regards.
12/4/2013 6:03:23 AM • Pitco Frialator... • Answered on Dec 04, 2013
How do I jump/bypass the high limit switch?
Hi there. Hi limits can be bypassed by connecting jumper wire from common to normally close terminals but this should only be done for testing purposes, if proven defective you have to replace it with a good one before using the unit in cooking. Hi limit is the safety device of fryers responsible for shutting the gas valve in case oil temp reaches 450f to avoid oil from catching fire. Regards.
11/25/2013 6:20:26 AM • Pitco Frialator... • Answered on Nov 25, 2013
My pilot light wouldn't stay lit. After lighting
Hi there. Check the hi-limit control, it may be tripping prematurely and needs replacement. Regards.
11/21/2013 3:41:23 AM • Pitco Frialator... • Answered on Nov 21, 2013
Do you have instructions on how to convert a deep
Visit http://www.middleby.com and go to PITCO web, you will be able to locate there the nearest authorized parts dealer on your area and ask for the conversion kit (from nat to lp). The gas valve conversion kit consists of spring, cap and instruction manual. you also need to replace the burner and pilot orifice, Nat pilot and burner orifice have larger bore than lp.
11/20/2013 9:21:53 PM • Pitco Frialator... • Answered on Nov 20, 2013
The burners will not light. The pilot does light.
The high limit switch has nothing to do with the pilot light, but will shut down the main burners. It the pilot light will not stay lit, then it is most likely the thermocouple. If the pilot light will not light at all, then gas is not reaching the pilot. Most likely, the pilot light tube is clogged with grease. When you push on the button to light the pilot, you are overriding all safeties inside the unit and sending gas to the pilot. Also make sure that the unit itself is getting gas. New regulations require a shut off within the hose that feeds the appliance which will shut off due to a surge of gas through the hose. To reset it, disconnect/reconnect the hose at the intake end and when you turn the gas back on, turn it on slowly.
10/7/2012 6:14:24 PM • Pitco Frialator... • Answered on Oct 07, 2012
Burner problem
Hi there! Check the incoming gas pressure.Insufficient gas pressure will greatly affect the unit's efficiency.Regards.
7/12/2012 7:43:47 AM • Pitco Frialator... • Answered on Jul 12, 2012
Pilot won't light at all on Pitco Frialator.
Would not be a good plan to do this your self gas valve replacement is a gas fitters job
5/29/2012 1:15:49 AM • Pitco Frialator... • Answered on May 29, 2012
Pitco Frialator 35CS Deep Fryer Logo
103 questions posted
Top Pitco Frialator Kitchen Appliances - Others Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Pitco Frialator Kitchen Appliances - Others
Most Popular Question
pilot won 39 t light all pitco
  • Kitchen Appliances - Others
