20 Most Recent Pitco Frialator SG14 Deep Fryer Questions & Answers
Fryer's Digital Controller will display "BOIL" if the temperature is it reading does not exceed 212F or 100C for quite some time. Make sure that there is enough level of oil (not water) in the Fry Pot before turning it on.
Pitco Frialator... | Answered on Apr 29, 2017
Sounds like propane. Please is heavier than air. Try opening air shutters on burners.
Pitco Frialator... | Answered on Dec 04, 2016
Sounds like thermostat or no fuel. Gas lines on? Correct orifice for the type of gas youre using?
Pitco Frialator... | Answered on Jun 13, 2016
call a good gas repairman sounds like your pressure regulator might be bad .
Pitco Frialator... | Answered on Nov 06, 2015
Wrong voltage thermocouple? must have 400mv, residential uses 25-40mv.
Pitco Frialator... | Answered on Sep 09, 2015
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Pitco Frialator... | Answered on Mar 04, 2015
Replace the thermophile
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Pitco Frialator... | Answered on Jul 16, 2014
first be sure the valve is in the on position. sounds crazy but I've been there. Next even though the pilot is lit it may not be burning hot enough to make the Thermo pile produce the 750 millivolts the valve needs to operate. If the thermo pile is producing the proper current then the gas valve itself is the culprit. If you are not comfortable with gas and do have the proper testers You should call a pro. The pilot is easy to clean though. turn the gas valve to the off position and remove the pilot. When you remove the gas line to the pilot there is a small oriface inside that looks like a little thimble. Remove it and clean it. the gas flows through a very small hole that clogs very easy. Reassmble it tighten the gas line. Check for leaks with some bubbles and give it a try.
Pitco Frialator... | Answered on Jun 06, 2014
Sounds crazy but check for power at the outlet. If that's good then possibly a bad cord,Power switch or interlock safety switch if it has one. Do you hear a humming sound when you try to use it? If so the motor is frozen up. Hope this helps.
Pitco Frialator... | Answered on May 25, 2014
If you have build up of soot you need a service and a gas fitter to do it .
Pitco Frialator... | Answered on May 15, 2014
You have your burners misaligned with the tubes. Re-align the burners and the welds will hold up fine.
SuperTech1
Pitco Frialator... | Answered on May 12, 2014
Pitco Frialator SG14 Deep Fryer Logo
Popular Tags
242 questions posted
Top Pitco Frialator Kitchen Appliances - Others Experts
Paul Carew
Treefrog15
Treefrog15
Joe Palazola
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Pitco Frialator Kitchen Appliances - Others
Most Popular Question
takes hour or more start mornings
  • Kitchen Appliances - Others
