20 Most Recent Sony Ericsson AINO/U10iwhite Questions & Answers
0answers
I own a SE Xperia Mini ST15i Black (android
Hi, Try restarting your wifi by switching of the power supply to the router.
12/18/2017 1:38:00 PM • Sony Ericsson... • Answered on Dec 18, 2017
Update firmware for nwz-b172f
himy mp3 player NWZ-B172F dont turn on plz help me? when connecting to usb port write verbinden m.usbtanx
6/10/2017 11:45:22 PM • Sony Ericsson... • Answered on Jun 10, 2017
MY LAPTOP GET HANG WHEN IN CONNECT TO INTERNET
Reinstall network driver.
5/8/2017 3:40:46 AM • Sony Ericsson... • Answered on May 08, 2017
0answers
Can you please reset this phone because I put a number password on it and forgot it
Dear friend,
You have not provided us your mobile model no.
Reply me with your mobile brand and its model no. And your country.
Regards,
Priyank Abhineet.
10/31/2012 6:10:19 AM • Sony Ericsson... • Answered on Oct 31, 2012
Unlock sony ericson k660i
You can use codes to unlock your Sony Ericsson k660i! Unlocking using codes is easy and also the safest method!! You can get the codes from your service provider or from reliable online sites like unlocking4u.com .You can get the codes by specifying Your phone's manufacture, model,country and network!The steps to unlock is simple here and the codes are affordable!!!!
6/4/2012 12:26:50 PM • Sony Ericsson... • Answered on Jun 04, 2012
I just bought a Sony
I upgraded my usb drivers -- I have windows xp pro -- i think they use all the same -- I used Realtek USB 2.0 card reader drivers. ( http://bit.ly/qeofyZ ) plugged it in (NOT in the front, but the back)_ & it recognized it after going to start, computer as "walkman" -- did a right click explore & all the data/music was still on the hard drive. then it showed on the walkman that it was charging & the battery was dead. i was previously using an AC usb adapter (plug in the wall) & it didn't seem to be charging it correctly -- so the computer works out for me & will only use that from now on -- fully operational.
7/16/2011 10:06:30 PM • Sony Ericsson... • Answered on Jul 16, 2011
0answers
K770i showing headphone symbol
head set signel c510i
1/26/2011 6:58:01 AM • Sony Ericsson... • Answered on Jan 26, 2011
My earphones will not work...when
Try adjusting your volume. If there is not a volume adjuster on your headphones, try turning it up on your phone. Hopefully it's not a shortage in the wire, which I don't think it is. Hope this solution helps; if not, reply back.
1/17/2011 5:28:42 PM • Sony Ericsson... • Answered on Jan 17, 2011
Booting error
Download Partition Table Doctor http://www.fileguru.com/apps/sony_walkman_mp3_nwz_b133f_boot_error/p2This will rebuild the device!!Best wishes to you!!!
1/16/2011 2:35:10 PM • Sony Ericsson... • Answered on Jan 16, 2011
My mp3 wont start .
connect it to a computer and install a software that says repair
10/15/2010 9:01:48 PM • Sony Ericsson... • Answered on Oct 15, 2010
Sanyo shpx310 Retractable Headphones
push the end of the headphone jack into the little white circle near on the left headphone where it retracts.
6/23/2009 2:48:22 AM • Sony Ericsson... • Answered on Jun 23, 2009
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first. But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
4/16/2024 5:57:29 AM • Audio Players &... • Answered 3 hours ago
Sony Ericsson AINO/U10iwhite Logo
3 questions posted
Top Sony Ericsson Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Sony Ericsson Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Ericsson Audio Players & Recorders
Most Popular Question
security code forgotten sony xperia
  • Audio Players & Recorders
