20 Most Recent Samsung Galaxy Player 4 8GB Android Tablet and Klipsch Image S4A 10138 Questions & Answers
Hi, Try downloading a new book. It should delete after download on it's own. It is like an mp3 player just download new books or music or picture etc... Good luck.
Samsung Galaxy... | Answered on Jun 03, 2015
If your phone gets wet. Turn it off immediately and remove the battery. Let it dry out naturally for quite a long period. this can be aided by leaving the back of the case off and the battery out.
If an attempt is made to power the player on before it is dry, the probability is that it will short out inside and never work again.
There is a phone on the market that will work under water but I can't remember the make.
Samsung Galaxy... | Answered on Apr 04, 2015
I had a similar problem with a galaxy Ace. I took it back to CarFoneWarehouse where it was fortunately under guarantee. They sent it away for repair but when it came back it was still doing the same. They gave me a brand new replacement in exchange.
So this fault of yours sounds the same. If it's still under warranty or contract, contact the supplier.
When you started your contract, the provider should have sent a text with their settings for your phone to work with them. You have to activate this text to activate those settings. If you check your providers web site you can check what these settings should be. Or you can phone your providers helpline to either resend the text or check your settings with you.
Otherwise it could be just a poor signal problem. A great phone signal doesn't mean you will have a good 3G signal.
Hi Dwayne, if you want a full reset goto > settings > accounts > Backup and reset > click "factory data reset"
Galaxy s4 reset
Contact Facebook. Once they have verified you are the correct user they will assist you in logging back in.
Is it a wi-fi network?
Then try first to reboot your galaxy.
If it still doesn't work, try to reboot the router. This solves 99% of these irrational problems.
Samsung Galaxy... | Answered on Feb 11, 2015
U be able to take it to Verizon. Theyll plug it up to their computer and transfer everything over I believe
Samsung Galaxy... | Answered on Jan 28, 2015
down load a soun bite app and set a sound as your notification alerts hopfull this workes for you
Samsung Galaxy... | Answered on Dec 10, 2014
The battery may be flat let it charge up .Or the battery be at fault.
Samsung Galaxy... | Answered on Sep 28, 2014
Connect to pc with usb cable and delete from within explorer.
Samsung Galaxy... | Answered on Sep 14, 2014
Most likely the phone is frozen. Remove the battery and re-insert it and start again. If this fails then you will have to try the factory reset (but may loose all the data and contacts saved on the phone).
see page 114 in this manual for details.
http://downloadcenter.samsung.com/content/UM/201205/20120516084910861/MID_YP-G1_English_User_Manual_KI8_F5.pdf
Samsung Galaxy... | Answered on Aug 17, 2014
I take it that yr in a very cold area.....these batteries loose their charge & cannot b recharged till U go 2 warmer climate!!!!
Samsung Galaxy... | Answered on Jul 23, 2014
Where are those pictures stored? If you have an SD card in the phone, how old is it? Do you have an SD card reader? You are most likely having the problem because of this card and you should atttempt to remove any pictures on it before going any further. The process to remove the pics means that you have to use a card reader and a computer. When you do that, you can then then restore or format the card and try it in the phone again.
Samsung Galaxy... | Answered on May 15, 2014
Samsung Galaxy Player 4 8GB Android Tablet and Klipsch Image S4A 10138 Logo
102 questions posted
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Audio Players & Recorders
Most Popular Question
delete book from library once read
  • Audio Players & Recorders
