20 Most Recent
LG 55ls4600 55" 1080p Led Lcd Flat Screen Tv Questions & Answers
I need to make my screen wider so I CAN SEE ALL OF GAMES
Try adjusting your resolution. Right click on your desktop and depending on your operating system, choose either properties or Screen Resolution. Adjust it in there to how you wish. Next time give more information so i can better assist you.
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
