20 Most Recent Casio GzOne Commando C771 Verizon Cdma Questions & Answers
What is GPRS?
General packet radio service General Packet Radio Service Please rate my answer, thk you.
11/8/2015 2:56:12 AM • Casio GzOne... • Answered on Nov 08, 2015
0answers
Im trying to figure out what all of the symbols on the home screen mean, on a cassio Commando
Hi LasGo to the following webpage and download the FREE user manual for your Casio it will explain all there is to know about your Casio.Please take time to rate meBudHi Make sure you are getting spark at the spark plug, to do this:Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.You do this by grounding the plug on the head of the engine and cranking the engine or by pulling the crank rope...watching the plug for spark.If you are getting a nice blue spark then skip A below and go to B. A...If you do not get a nice blue spark then you may need to replace the electronic module.Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.Take a picture for later reassembly. B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.Then follow the procedure below:------------------------------------------------------------------------------------Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible. Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel. Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT. Note:Before you disassemble the carburetor:Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.That way you will know which way it goes back together when you reassemble it. Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.Check you fuel line/s condition...after a while they will degrade and need replacement. Check/Clean/Replace your fuel filter if you have one.When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.Also a good time to take a picture for later reference for reassembly. If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc. When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.Be sure to mark the turns down on a piece of paper.That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.Once you have your carburetor cleaned/rebuilt that should solve your problem.Please take time to rate me Budhttp://nec-casio-mobile.com/support/download/GzOne_COMMANDO_Eng.pdf
10/29/2012 5:57:30 PM • Casio GzOne... • Answered on Oct 29, 2012
No sound on my casio mz-2000
Hi, Please first make sure that the volume is turned up and that there is no earphones connected to the piano. Because either of these things could lead to the issue that you're describing. If these actions don't work, please refer to the troubleshooting section of your device's manual for more procedures. Thank you.
10/11/2022 1:14:55 AM • Casio Audio... • Answered on Oct 11, 2022
My Casio 800 starts playing beats or music on it's own whenever I turn it on. And i can't play anything or stop it, until I put it off. What can I do please. Thanks
Sounds like a stuck key or button. Press them all and see which one feels odd.
CT-X800 - Coolblue
https://manuals.coolblue.nl > casio-ct-x800
PDF RECORD 1 - 6 - CTX800-ES-1A ... You can use a computer to download music score data from the CASIO Website. ... Any reproduction of the contents of this manual, either in part or its entirety, is prohibited. ... first beat of each measure of the song you are playing. ... While tap rhythm start is enabled, rhythm can be started in. ..
5/6/2021 5:43:13 PM • Casio Audio... • Answered on May 06, 2021
How do you remove speaker cover off a Casio wk
You are in Minidisc Players.
4/16/2014 2:01:09 PM • Casio Audio... • Answered on Apr 16, 2014
0answers
0answers
I have a casio phone mate ta-140 and it won't
Thank you for posting your question on fixya. I will be happy to help you with this problem. Can you please give us some more information so I can better answer your questions.
Do you have the manual with you?.
If no, to be able to get the manual for help you will need to call 800-706-2534 option 1 for that manual as it's not available on their website. you may want to try the 150 manual as they are very close:
http://www.casio.com/support/manuals/answeringmachines/ta150.pdf
Thank you,
9/14/2011 10:33:22 AM • Casio Audio... • Answered on Sep 14, 2011
0answers
Casio keyboard LK 108 manual
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to provide you with your request. You are requesting a Casio Keyboard LK-108 Owner's Manual? The link below will take you to the Casio Support website where you can click the link to download your owner's manual.
http://support.casio.com/manualfile.php?rgn=1&cid=008006016
7/7/2011 6:06:37 AM • Casio Audio... • Answered on Jul 07, 2011
I need a Casio Tone
Free PDF Manual at the link below.
http://www.usersmanualguide.com/manuals/casio/CT-670.pdf
Please leave feedback.
Cheers
Andy
6/9/2011 11:23:41 PM • Casio Audio... • Answered on Jun 09, 2011
We have recently moved and
yes it is..there are many available on that
2/23/2011 2:42:48 AM • Casio Audio... • Answered on Feb 23, 2011
DRIVERS
Hi, You may visit your provider MP3 & Digital Media Players for your driver.
Hope this is helpful.
Thanks.
2/7/2011 7:22:49 AM • Casio Audio... • Answered on Feb 07, 2011
I have the casio px130
there is a special kind of tape that you use try going to the music store and ask for it
12/26/2010 11:54:42 PM • Casio Audio... • Answered on Dec 26, 2010
0answers
Casio GzOne Commando C771 Verizon Cdma Logo
21 questions posted
Top Casio Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Casio Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Casio Audio Players & Recorders
Most Popular Question
gprs
  • Audio Players & Recorders
