20 Most Recent
Samsung Officeserv 5014d Ds5014 Ds-5014d Speaker Phone Telephone W/ Warranty Questions & Answers
Samsung IDCS 28D system: How do I unblock access to outside lines? No lights show on the dead lines. Handset works in other offices.
It is possible that the outside lines have been blocked in the programming of the Samsung IDCS 28D system. You can try the following steps to unblock the outside lines:
- On a phone that is working, press the TRANSFER button and dial 200.
- Enter your system password. If you don't know your system password, you may need to contact your phone system administrator or service provider.
- Press 713 for "Line Block Release".
- Press the button for the line that is blocked (in your case, all 4 lines).
- The display should show "RELEASE OK" for each line that is unblocked.
- Hang up the phone.
If this doesn't work, it is possible that the phone system may need further troubleshooting or programming by a technician.
Samsung IDCS 28D system Outside lines blocked by accident. How can I undo it please?
To unblock the outside lines on a Samsung IDCS 28D system, you can follow these steps:
- Press the "Transfer" button on your phone.
- Dial "741".
- Press the "Transfer" button again.
This should unblock the outside lines on your system. If this does not work, you can try resetting the system by unplugging it for a few minutes and then plugging it back in. If the issue persists, you may need to contact a professional to troubleshoot the system further.
Samsung iDCS 28D Calls not going to VM after canceling a forward on no answer
It's possible that when you cleared the forward on no answer, the voicemail setting on your Samsung iDCS 28D was not properly restored. Here are some troubleshooting steps you can try:
- Check your voicemail settings: Dial 604 and press the "Speaker" button. Enter your extension number and press the "Speaker" button again. The system should confirm that you have entered the correct extension number. If it does not accept your extension, try dialing from a different phone to make sure that your extension is still active.
- Verify your call routing: Dial 601 and press the "Speaker" button. This will show you the current call routing for your extension. Verify that "No Answer" is set to go to your voicemail box. If it is not, you can change it by pressing the "Speaker" button and entering the appropriate code for voicemail (usually "72").
- Restart the phone system: If the above steps do not work, try restarting the phone system. You can do this by unplugging the power cable from the phone system for a few seconds and then plugging it back in.
If none of these steps resolve the issue, you may need to contact your phone system administrator or IT support for further assistance.
I have a Samsung OfficeServ DS-5038S. An extension light keeps flashing red. When i dial the extension it gives the engaged tone but there is no one using the phone. What could it be?
If an extension light on your Samsung OfficeServ DS-5038S phone is flashing red and dialing the extension gives an engaged tone even though no one is using the phone, it's possible that the extension is stuck in a busy or engaged state. Here are some steps you can try to resolve the issue:
- Check the extension: Go to the extension in question and make sure the handset is on the hook and that there are no other phones or devices using the line.
- Restart the phone: Try restarting the phone by unplugging it from the power source for a few seconds, then plugging it back in.
- Check the programming: It's possible that there is an issue with the phone's programming. Check the phone's user manual or contact your phone system administrator to ensure that the extension is programmed correctly.
- Check the phone system: If the issue persists, it may be necessary to check the phone system itself for any issues that could be causing the extension to appear busy or engaged.
- Replace the phone: If none of the above steps resolve the issue, it's possible that there is a hardware issue with the phone itself. Consider replacing the phone or contacting a qualified technician for further assistance.
It's important to note that some phone systems are configured to automatically put extensions into a busy or engaged state after a certain period of time to prevent unauthorized access. If this is the case, contact your phone system administrator to adjust the settings accordingly.
