20 Most Recent Sylvania Dvd & 4 Head 19 Micron Hq Vhs Player Dvc840f Questions & Answers
Is it possible to cast/mirror/ etc. from ab android phone to a Sylvania TV manufactured in 2005?
No, because screen casting wasn't invented and it isn't a Smart television. Time for a new one.
3/11/2024 8:53:32 PM • Sylvania... • Answered on Mar 11, 2024
I have an old Sylvania tv and it won't turn on
Here are some troubleshooting tips to try. However, as it is an older set, if these tips fail, the cost of a repair at a shop might exceed the value of the TV. In short, a new TV may be in the works. Cross your fingers. One of these tips may work. Let's troubleshoot the issue and try to get it working: If you are using a remote, check the batteries in it. If you are using several remotes with it, try the alternative remote. Sometimes there is a glitch affecting the remote for a Roku where it won't turn on the TV other than a powered black screen and you have to use the other remote to turn it off and back on and then the Roku screen pops up. I have not sorted out why. Check Power Cord and Connections: First, ensure that the power cord is securely plugged into both the TV and the electrical outlet. If you suspect a faulty power cord, consider trying a different one. Reset the TV: While most Sylvania TVs don't have a dedicated reset button, you can perform a manual reset: Unplug the TV's AC adapter from the electrical socket. Press and hold the Power button on the TV for 20 seconds. Plug the AC adapter back in and turn on the TV. Check Audio/Video Cables: Inspect the audio/video cables connecting your TV to the satellite or cable receiver. Ensure that the color-coded prongs match their respective connecting points. Correct any mismatches (e.g., white cable into a red port) by reorganizing the prongs. Inspect Coaxial Cable: Look for the coaxial cable on the rear side of the receiver, attached to the port labeled as ANT IN. Confirm that the connection is firm; a loose coaxial connection can cause display issues. Tighten the cable by pinching the silver band on the end and rotating it clockwise until secure. Check for Interference: If distortion continues on the TV screen, consider nearby interference. Power-hungry appliances can cause electronic interference, affecting display quality. Visit a Repair Shop: If the above steps don't resolve the issue, you may need professional help. Some technical faults, such as a blown fuse or faulty capacitor, require expertise in dismantling and soldering. If uncomfortable with such tasks, consider visiting a repair shop
2/3/2024 6:17:20 AM • Sylvania... • Answered on Feb 03, 2024
2answers
I have a 37in limited edition Sylvania TV I have tried every code on my Phillips universal remote none work. Is there a specific code.
  1. Auto Code Search:
    • Turn on your Sylvania TV.
    • Press and hold the "Code Search" button on your Philips remote until the indicator light stays on.
    • Press the "TV" button on the remote to set it to control the TV.
    • Press the "Power" button repeatedly until the TV turns off.
    • Press the "OK" or "Enter" button to save the code.
  2. Manual Code Entry:
    • Find the code for your Sylvania TV in the Philips remote control manual. If you don't have the manual, you may be able to find it on the Philips website.
    • Press and hold the "Code Search" button on the remote until the indicator light stays on.
    • Enter the code using the number buttons on the remote.
    • Test if the remote now controls your TV. If not, repeat the process with a different code.
  3. Try Common Codes:
    • Some common Sylvania TV remote codes for Philips remotes are 0810, 1684, 1886, 2183, 1081, 1172, 1196, and 2049. Try entering these codes manually.
1/9/2024 10:32:14 PM • Sylvania... • Answered on Jan 09, 2024
Sylvania tv with vcr/dvd player. vcr tape keep being ejected even when using tape cleanser ejected
The most likely cause is a faulty mode switch.
12/12/2023 10:12:41 PM • Sylvania... • Answered on Dec 12, 2023
2answers
Flashing colors on Sylvania lcd TV
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
11/5/2023 2:26:58 AM • Sylvania... • Answered on Nov 05, 2023
Why no tv picture on my Sylvania #ssc092 ac/dc tv/vcr combo?
it is a very simple TV, is TV connected to cable? Here is link to manual copy and past download and save for future reference. It is very old and has CRT not LCD. https://www.manualslib.com/manual/776815/Sylvania-Sylvania-Ssc092.html#manual
10/20/2023 4:15:16 PM • Sylvania... • Answered on Oct 20, 2023
Sylvania tv screen went black last night when we hit a channel button on remote
More likely you hit the Source / Input button and lost the signal. Press it again until it comes back.
9/13/2023 4:08:17 AM • Sylvania... • Answered on Sep 13, 2023
Codes for a Sylvania 32'tv
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote 4-Digit Sylvania TV Codes for Universal Remote
  • 0002.
  • 0008.
  • 0030.
  • 0054.
  • 0068.
  • 0096.
  • 0171.
  • 0321.
More items... • Jan 1, 2023
RCA Universal Remote Codes For Sylvania TV - GenTwenty
6/22/2023 5:33:00 AM • Sylvania... • Answered on Jun 22, 2023
How can I unlock my PIN# on my sylvania smart tablet, and DVD 10.1.
By typing the correct pin or activating a factory reset.
6/17/2023 8:57:49 PM • Sylvania... • Answered on Jun 17, 2023
Does sylvania LC260SS2 support earc/arc with the hdmi inputs?
The Sylvania LC260SS2 has a eArc option called fun-Link. This only works with other fun-Link compatible devices. See https://www.manualslib.com/manual/325827/Sylvania-Lc260ss2.html?page=14#manual . (Sylvania TVs are made by Funai Electric.) It may not work with non-Funai electronics. I hope this helps. Cindy Wells
4/25/2023 10:32:56 PM • Sylvania... • Answered on Apr 25, 2023
I need the codes for DVD players I have a Sylvania and the easy setup isn't working so I need the code and the hard way to set it up.
Sylvania DVD Player Remote Control Codes
codesforuniversalremotes.com https://codesforuniversalremotes.com > sylvania-dvd-p... Program your universal remote control to a Sylvania DVD player. Use the following remote codes. Sylvania DVD Player 4 Digit Remote Control Codes: 2213 2260 2321
Sylvania DVD Player Universal Remote Codes
universalremote.codes https://universalremote.codes > sylvania-dvd Feb 14, 2021 - First of all "Turn The Device On" · Now press and hold the "Setup" button · Enter the "9-9-1" (three digit) code · Now hold down the "Power Button" ...
directutor.com https://www.directutor.com > content > sylvania-dvd-p... Sylvania DVD Player Remote Control Codes ... GE Universal Remote Codes with Program Instructions. sameeha ... Smart TV Universal Remote Codes By TV Brand. ..
3/25/2023 6:17:57 PM • Sylvania... • Answered on Mar 25, 2023
Can the Sylvania LC320SLX be connected to the WiFi for streaming viewing...???
Of course not. It is an old and simple set from 2009 and perfect for a bedroom
Sylvania LC320SLX LCD TV (LC320SLX)
http://www.hdtvsolutions.com > Sylvania-LC320SLX A smart and trusted choice for everyone. The LC320SLX offers high-level video and audio entertainment in a stylish package. View high-definition programs in ... Component (HDTV): 3 RCAs Formats: 480i, 480p, 720p, 1080i Screen Size: 32" Diagonal HDMI: HDMI (3 sets)
3/7/2023 5:50:48 AM • Sylvania... • Answered on Mar 07, 2023
2answers
I have a Sylvania 55inch LED 4K TV Model SL551ANU that has sound but no image.
If your Sylvania 55-inch LED 4K TV has sound but no image, it could be due to several reasons. Here are some steps you can take to troubleshoot the issue:
  1. Check the connections: Make sure that all the cables connecting your TV to other devices, such as cable boxes or gaming consoles, are properly plugged in and secured. If any cables are loose, reattach them and try turning on the TV again.
  2. Check the input source: Make sure that the TV is set to the correct input source. If you're not sure, cycle through the different input sources using the remote control to see if the image appears on any of them.
  3. Adjust the brightness: Sometimes, the brightness of the TV can be too low, making it appear as if there is no image. Use the remote control to adjust the brightness of the TV and see if the image appears.
  4. Perform a power cycle: Turn off the TV and unplug it from the power source. Wait for about 30 seconds, then plug it back in and turn it on again. This will reset the TV and may fix the issue.
  5. Contact the manufacturer: If none of these steps work, it may be a hardware issue. Contact the manufacturer or a qualified technician to diagnose and fix the issue.
It's important to note that attempting to fix the TV yourself may void the warranty or cause further damage.
2/21/2023 3:30:34 PM • Sylvania... • Answered on Feb 21, 2023
2answers
SYLVANIA TV does not power on
  1. Check the power outlet: First, try plugging the TV into a different power outlet to make sure that the issue is not with the outlet itself.
  2. Check the power cord: Make sure that the power cord is securely plugged into both the TV and the power outlet. Check to see if the cord is damaged or frayed in any way, which could prevent the TV from receiving power.
  3. Test the power inverter: You can test the power inverter using a multimeter to determine if it is functioning properly. If it is not working, you may need to replace it.
  4. Check the TV's internal components: If the power inverter is functioning properly, there may be an issue with one of the TV's internal components, such as the power supply board or the main board. In this case, you may need to have the TV repaired by a professional technician.
2/15/2023 3:00:23 AM • Sylvania... • Answered on Feb 15, 2023
2answers
My Old Sylvania TV Is Stuck In Stuck With No Remote
If you do not have a remote for your Sylvania TV, you can try using the buttons on the TV itself to navigate through the settings and change it back to the video screen. Look for a button on the TV labeled "Menu," "Settings," or something similar, and use the arrow buttons to navigate through the options. You may need to consult the TV's manual for specific instructions on how to navigate the settings without a remote. If you don't have the manual, you can try to find it online on the Sylvania website or by searching for it on the web with the TV's model number.
1/25/2023 12:41:02 AM • Sylvania... • Answered on Jan 25, 2023
On my TV, a Sylvania LC260ss2, how do I change aspect ratio with a remote?
You won't get a 'direct answer' here. We are Fixya, we aren't Sylvania. Settings > Screen Mode > Aspect Ratio is the normal way. Once you are in there toggle through the settings normally using arrow buttons and Enter. https://www.google.com/search?q=Sylvania+LC260ss2%2C+change+aspect+ratio ..
12/11/2022 9:18:12 PM • Sylvania... • Answered on Dec 11, 2022
2answers
Can I use a universal remote app for sylvania LC320SL1
Hi. It depends on the remote. If the remote app has the codes for your Sylvania tv, then you can use the remote. Check the list of codes that comes with the remote app and if it includes Sylvania codes, then there is a high possibility that the app will work with the tv. Thank you.
11/26/2022 4:16:02 AM • Sylvania... • Answered on Nov 26, 2022
Sylvania Dvd & 4 Head 19 Micron Hq Vhs Player Dvc840f Logo
5 questions posted
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
sylvania lc320slx connected wifi
  • Televison & Video
