20 Most Recent
NEC AccuSync LCD92VXM-BK - LCD display - TFT - 19" - 1280 x 1024 / 75 Hz - 250 cd/m2 - 500:1 - 8 ms - 0.294 mm - DVI-D, VGA - speakers - black Questions & Answers
NEC VH-605 VCR - Very Snowy Picture
Video head needs thorough cleaning. If no head cleaner, then run a few long tapes through it in the fast scan mode since the tape itself is abrasive and will over time remove debris from the heads. If that does not do it, try a chemical cleaner to dissolve the material.
9/1/2017 12:39:35 PM •
NEC Audio...
Answered
on Sep 01, 2017
No mixer, audio to have
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
2/24/2011 5:50:34 AM •
NEC Audio...
Answered
on Feb 24, 2011
I cannot open my computer because license of
You might just be able to go to:
Start > Control Panel > System
You should see a place where the product key is. There might be a button there to activate or put in a new key. What you need to do is look at the sticker on the side of your computer and there will be a Windows Product Key there. Just input that one in because it is the correct number.
That should work. I just had the same problem on mine. It had some number already in it but it was wrong. I had to get the real number off that sticker. Once you buy Windows, it doesn't go away, it is yours forever - unless you just downloaded a trial version or something.
12/7/2009 9:32:03 PM •
NEC Audio...
Answered
on Dec 07, 2009
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
