20 Most Recent Motorola Mobility XT3 QUENCH XT502 3.2MP ANDROID UNLOCKED PHONE Questions & Answers
Hi Sohil,
Sadly, if you're unable to get past the lock pattern, you'll have to perform a factory reset. Please follow the steps below to factory reset your device. Keep in mind this will delete all content from the phone.
  • Power off the device
  • Press and hold the R and M keys while pressing the Power button. You will see the red M logo on your screen then the screen with the Android-bot and a blue exclamation mark inside a white triangle
  • Once this screen appears, press both Volume Up and Down keys, then release to get the Android system recovery
  • Use the Volume Up and Volume down buttons to select wipe data/factory reset
  • Choose Yes -- delete all user data to confirm that you would like to wipe all data from the device and press the Return key
  • Your device should now cycle through the wiping/reset process and return to the Android system recovery screen
  • After userdata is cleared, the "reboot system now" option will be highlighted by default. Press the return key to power off/on your device
  • It will take a few moments to arrive at the initial Android Welcome screen.
  • Your phone will reboot and be back to factory settings. You can now set everything back up on your phone again.
    Thank you,
    Tom
    Motorola Support
    MOTOROLA PRO PLUS Factory Data Reset
    Motorola... | Answered on Apr 26, 2019
    If you are a good handyman you can do the following: (1) Go to a hardware store and buy a cheat DVM (digital voltmeter). Go to the other bulb and measure the voltage and write down on paper. Then CAREFULLY remove the bulb and place it where the other one burnt out twice. Measure the voltage the same way. If the two voltages are identical, then it was simply a coincidence, take the burnt bulb and go to the Electronic Parts Store and buy two bulbs (the reason for two is that the other one remaining will also go not before too long). If the voltage is ghigher than the previous reading, take it to the attention of the manufacturer. There is a design error by their engineers and they need to fix it. They most likely will send you a new unit and ask to return the old one, so they can evaluate it. Now when we are talking about volts, we talk about tenths of volts difference. This scheme will also work with LEDs, but the bulb with the lower voltage is the one at fault. CONSTANTIN
    Audio Players &... | Answered 3 hours ago
    Go to Alba's wed site and look for downloads where you should find operating instuctions.
    Sorry i couldnt find it .
    However i found a review that should cover all speaker functions . Below is the link
    https://youtu.be/urb8Ai6yOP0
    Audio Players &... | Answered 12 hours ago
    Hello Kristine, indicate brand, model and type of equipment that you are commenting on, in order to find the best possible solution
    I wait your answer
    Greetings Franco Dosil
    Hola Kristine, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
    Espero tu respuesta
    Saludos Franco Dosil
    Can anyone please help me.. may megavision ako, I connect it to my sony tv and sony home theatet system pero pag kumanta ako may delays sa voice ko.ano po pwede ko gawin para mawala yun please helppp...
    Audio Players &... | Answered Yesterday
    if it have headphone jack,,,connect head phone if it work ...check its speaker.....if speaker is OK then replace its audio IC....if you are electronics knowing person...
    Google (wedge)(A4116)(manual) without parens.
    Audio Players &... | Answered 2 days ago
    There is no magic mouse milk for it. The weight should be enough to keep the styles in grove (just enough) It is not difficult to set up the tone arm.Use a good quality cartridge. There is needle it is a stylus
    I use 2 AT turntables from the 1970's
    https://www.youtube.com/watch?v=W30v3CqG8kY
    https://www.youtube.com/watch?v=jizk-3JGzag
    Track my order
    Hi, I think it's great that you want to follow your order
    Please indicate what you need, to try to find the best possible solution
    I hope you answer
    Hola , me parece muy bien que quieras seguir tu orden
    Por favor indica que necesitas, para tratar de encontrar la mejor soluci?n posible
    Espero te respuesta
    Hello Gloria, please indicate what you need, to try to find the best possible solution
    I hope you answer
    Hola Gloria, por favor indica que necesitas, para tratar de encontrar la mejor soluci?n posible
    Espero te respuesta
    Motorola Mobility XT3 QUENCH XT502 3.2MP ANDROID UNLOCKED PHONE Logo
    1 questions posted
    Top Motorola Mobility Audio Players & Recorders Experts
    ka4iup
    ka4iup
    john h
    Andrew Taylor
    Andrew Taylor
    Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
    View Most Popular
    • Motorola Mobility Audio Players & Recorders
    Most Popular Question
    many pattern lock attampt but no benefit
    • Audio Players & Recorders
