20 Most Recent
LaCie Biggest F800 (300942U) 250 GB Hard Drive Array Questions & Answers
La Cie Biggest F800 is down
Try hitting the reset button, on some raid arrays I have had the motherboard go to sleep mode and do the same thing so if you hit the reset button it should bring it back up. if not you will have to unplug and leave unplugged for 5 minutes before static power dies out then try rebooting. you may have to do a flash of the bios and have you done any updates of late?
I need to know how to do a factory reset on a lacie 4Big Quadra enterprise.
- Disconnect all cables from the device.
- Press and hold the "reset" button (located on the rear panel) for about 10 seconds.
- Wait for the device to restart and initialize. This may take several minutes.
- Reconnect the cables to the device and try accessing it again.
Note: It's recommended to backup all data stored on the device before performing a factory reset, as all data will be lost during the reset process.
My LaCie external drive isn't getting power
U should test for power at the connector that goes into the lacie with a voltmeter to make sure power supply and its wire are OK. If no voltmeter then use a automobile brake or turn signal bulb to see if it has power.
Lacie n2870 driver
You need a new driver for sure, and here you can find it
driverupdate us. This tool usually keep my drivers up to date (perfectly for now)
take a look
