20 Most Recent
LaCie (300950) 400 GB Hard Drive Questions & Answers
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
200 gb d2 extreme
The whining noise and the low clicking sound are indicate mechnical problem.
My recommendation to you is to backup all the important data you have on it ASAP before it will crash and you will not able to do it !!!!
Hard drive is "full" though I only have 186G on it
hereĀ“s a thought!
You can try running chkdsk cause maybe your freespace is being reported incorrectly!
Open command prompt:
Go to Start->Run then type cmd and press enter
Run the chkdsk utility:
where x is the drive letter of the removable drive
at the prompt type chkdsk x: /f and press enter
now windows will scan for filesystem errors and fix any if found.
Also on another note, items in your recycle bin count towards the amount of used space!
hope this helps
regards,
babb
I need to know how to do a factory reset on a lacie 4Big Quadra enterprise.
- Disconnect all cables from the device.
- Press and hold the "reset" button (located on the rear panel) for about 10 seconds.
- Wait for the device to restart and initialize. This may take several minutes.
- Reconnect the cables to the device and try accessing it again.
Note: It's recommended to backup all data stored on the device before performing a factory reset, as all data will be lost during the reset process.
My LaCie external drive isn't getting power
U should test for power at the connector that goes into the lacie with a voltmeter to make sure power supply and its wire are OK. If no voltmeter then use a automobile brake or turn signal bulb to see if it has power.
Lacie n2870 driver
You need a new driver for sure, and here you can find it
driverupdate us. This tool usually keep my drivers up to date (perfectly for now)
take a look
