20 Most Recent
Lexmark Z705 Inkjet Printer Questions & Answers
Hp printer printing off center
Try uninstalling the printer completely and if you have a current install disc compatible with your operating system then re-install with that. It may prove better if you go to the manufacturer's website, click on support and follow directions that will be there to identify your printer and download and install the latest drivers. When installing disconnect the USB lead until the program asks you to plug it in. God luck.
I have lexmark Z705 and when I print I get message
check in device manager if the device is detected, check the cables connecting the device , swap ends of the cable if needed install drivers and if you dont have drivers do a system restore to the date the printer was being detected!
Enjoy
My lexmark will not print envelopes. IT will
Both my Hp1220 (which is pretty old) and my Epson C62 will print envelopes,so I'm sure yours will. You need to go into the print preferences (possibly advanced) and set the SIZE,not paper type to the size envelope you need to print.I have the options of #10,DL & C6.
I think those are the standard sizes.
Let me know.
Bob
I cant get my printer to print
1. Turn it on
2. Install the software from the CD-ROM that came with the printer,
or access
http://support.lexmark.com and search for 'Z705', and download the latest device-drivers for your specific Operating System
3. Connect the printer to your computer, and wait a few seconds, until Windows recognizes it
4. Print something
I have an old model Z705 and I don't have the
Yes, take your printer to any staples store or even a walmart [electronics/computer dept] and get the cable you need.. You eill also need the disk for that printer which you can download for free by googling lexmark Z705 Driver.
Lexmark z705 printing blank envelopes soft ware ok
The problem that you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge.
You can fix this problem with one of two ways:
1. Click on "Start", "Control Panel" and click on "Printers and Faxes." Right click on the "Lexmark Printer" icon and select "Properties." Click on "Printing Preferences." Go to "Quality/Copies" tab and select the option "Print color images in black and white."
2. You can also change the color of you text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink, please follow the steps given below:
Clean Nozzle Procedure:
1. Go to the "Solution Center" and click on the "Maintenance" tab.
2. Select "Clean to fix horizontal strips."
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzles" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
“Wicking” Procedure:
1. Select "Install color/black cartridge" and remove the cartridge from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridge back into the printer.
7. On your computer, select "Old Cartridge installed."
8. Repeat the "Clean to fix horizontal strips" procedure listed above.
If this procedure does not help, please let us know so that we can continue with technical support.
Printer printing blank evelopes
Check your setup in your envelope printing software, make sure it's set for the size envelope you're using, it might be printing in the air next to the envelope.
