20 Most Recent APC Smart-UPS 1500VA Shipboard (SUA1500X93) UPS System Questions & Answers
A smart ups 1400 stopped working
First cheack the supply if supply is present the then cheach the cable which is connected between power supply and the ups if this things are working properly then open the ups and then go to the power supply section by tracing the ip put from the power supply switch you will find the fuse over there
12/22/2018 6:02:13 AM • APC Smart-UPS... • Answered on Dec 22, 2018
How to find out damaged battery unit in 30kva apc smart ups VT?
pull them out, examine each one for cracks, bulging, leaking, then check the voltage. Should be around 12.25v fully charged.
11/28/2014 8:36:50 PM • APC Smart-UPS... • Answered on Nov 28, 2014
Fan comes on periodically
When it gets to warm the fan cools it down. When it's cool the fan will shut down.
11/28/2014 8:20:51 PM • APC Smart-UPS... • Answered on Nov 28, 2014
3answers
Smart apc ups error with all indicator flashing .
APC Smart-UPS 1500VA has an error. All it's pannel lights blinking. what is the best possible solution to this?
7/9/2014 3:00:58 AM • APC Smart-UPS... • Answered on Jul 09, 2014
Apc ups repair
Virgile,APC / Schneider has kept been pretty difficult to repair from online instructions... especially their bigger UPS units. They offer a course you can pay for... and you can always look for a job with them. Aside from that though... there isn't much floating around.Good Luck!Daniel • [email protected] • Power & Systems Innovations • 800.260.2259 • www.psihq.com
11/7/2013 4:08:32 PM • APC Smart-UPS... • Answered on Nov 07, 2013
Lost my mains lead for a 1500VA APC UPS . What
use 5A fuse
2/21/2013 3:13:59 AM • APC Smart-UPS... • Answered on Feb 21, 2013
UPS indicating overload when all
inverter circuit is faulty, send your UPS to APC authorized service center
2/21/2013 3:11:54 AM • APC Smart-UPS... • Answered on Feb 21, 2013
My smart ups 1500 not charging battery and avr not lit while the utlity voltage is 210
Might need to replace batteries. This is usually the cause.
8/27/2012 10:29:28 AM • APC Smart-UPS... • Answered on Aug 27, 2012
2answers
yeppers...those APC units sometimes kick the monitoring software. sometimes you need to unhook the connection cables(like a reset) so that the firmware can 'unlock' which can cause that christmas tree effect on the panel lights.
8/6/2012 1:46:44 PM • APC Smart-UPS... • Answered on Aug 06, 2012
Ups blinking continuosely
check the charging ckt
8/6/2010 9:42:34 AM • APC Smart-UPS... • Answered on Aug 06, 2010
2answers
Can i use my ups on server ml370 1500va apc smart
sure as long as the APC is the same voltage.
5/8/2010 10:15:51 AM • APC Smart-UPS... • Answered on May 08, 2010
Hi my APC 1500VA smart UPS show overload
Contact APC Customer Service. They will help you resolve this. If unit is still under warranty they will replace it. There is nothing you can do to repair anything yourself. Sorry ... try calling 1-800-555-2725800-555-2725 for support from APC
5/6/2010 11:47:24 PM • APC Smart-UPS... • Answered on May 06, 2010
About ups
If you remove all of the equipment plugged into the UPS, is it still lit?
Are you sure this is an overload light, and not a replace battery light? If this is a smart-ups unit, the overload light is next to a picture that looks like an unbalanced scale. The replace battery light is a square with an X through it.
If it is, in fact an overload light that is lit, and it stays lit with less than the maximum load on it, or without any load on it, then you have a critical internal failure and the unit needs to be replaced or repaired.
You can also find your user manual here for more information: http://www.refurbups.com/Knowledge-Base
3/31/2010 1:58:33 PM • APC Smart-UPS... • Answered on Mar 31, 2010
Can i use APC smart ups 1500va to support my hp
yes
1/12/2010 9:17:13 AM • APC Smart-UPS... • Answered on Jan 12, 2010
2answers
Need SERVICE MANUAL W/SCHEMATIC &
I found the information online and downloaded it.
12/12/2009 5:15:43 PM • APC Smart-UPS... • Answered on Dec 12, 2009
APC Smart-UPS 1500VA Shipboard (SUA1500X93) UPS System Logo
Popular Tags
38 questions posted
Top APC Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • APC Computers & Internet
Most Popular Question
ups blinking continuosely
  • Computers & Internet
