20 Most Recent Lexmark X4250 All-In-One InkJet Printer Questions & Answers
Lexmark 4126-k01 printer driver free download
Please visit the Lexmark website, www.lexmark.com Support or Driver and Downloads.
Search by using the printer model and operating system that you need the driver for.
If you do not see a driver for the printer, then more than likely Lexmark has made a decision that the technology in the printer no longer matches up with the current demands of both software and hardware.
Don
11/13/2018 1:18:51 PM • Lexmark X4250... • Answered on Nov 13, 2018
How do I fix a 1203 error if it's not the cartridge?
Try this. http://support.lexmark.com/index?page=content&productCode=LEXMARK_X4270&segment=SUPPORT&userlocale=EN_US&id=HO2622 When you take the cartridges out, clean thoroughly the contacts and see if there is any residue from the label that is removed or dirty contacts.
9/11/2014 5:06:26 AM • Lexmark X4250... • Answered on Sep 11, 2014
Unable to install HCL Lexmark H505 4126 printer to my laptop with windows 7 from original CD supplied with printer 5 years old
I had a similar problem with my HP 3650. I can install my printer on windows XP but not windows 7. I had to download the drivers compatible with windows 7 for the printer on the internet,Hope this will help
2/29/2012 11:21:49 AM • Lexmark X4250... • Answered on Feb 29, 2012
Lexmark x4250 prints black bars when scanning'
Contact Lexmark and Get the Scanner Replaced if its Under Warranty as the Flat Bed Scanner is not working Fine and its Malfunctioning
10/5/2011 9:35:07 AM • Lexmark X4250... • Answered on Oct 05, 2011
Everything is working fine on
It could be the fax line in the wall. Try to insert a telephone straight to the wall and listen for a dial tone. If you hear no dial tone, please contact your phone company and have them check the line. If you hear a dial tone, re-plug the printer into the wall using a different known working telephone cable. Try to fax again.
9/2/2011 6:08:20 PM • Lexmark X4250... • Answered on Sep 02, 2011
Hi i need lexmark 4126
8/2/2011 5:29:31 AM • Lexmark X4250... • Answered on Aug 02, 2011
Error 1203 was acured when
Hi
Please check you fix the cartridge is properly and with right place (Black to Black) (Color to Color)
5/12/2011 2:35:36 PM • Lexmark X4250... • Answered on May 12, 2011
2answers
How to download lexmark 4126 installation cd
click here and download the drivers..
3/10/2011 12:53:02 PM • Lexmark X4250... • Answered on Mar 10, 2011
I have done solution 1 to get cartrage moving, but
The "1200" error message can be caused either by the cartridges that are not snapped in correctly, the encoder strip (transparent strip) is not in its position or something is blocking the cartridge carrier path. Please refer to this article in the Lexmark website on 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One. If problem continues, please contact Lexmark technical support for additional assistance. Thanks.
3/8/2011 2:47:13 PM • Lexmark X4250... • Answered on Mar 08, 2011
Can you print with only
Sorry, but Lexmark does a check on the color cartridges before printing. Even if you are only printing in B/W, the printer will refuse to work without color cartridges installed and full of ink.
2/28/2011 4:03:33 PM • Lexmark X4250... • Answered on Feb 28, 2011
My Lexmark X4250 printer prints
Sometimes, it take awhile for the ink to reach completely into the printhead.
Perform a printhead cleaning cycle should correct the problem.
2/14/2011 6:22:39 AM • Lexmark X4250... • Answered on Feb 14, 2011
Error1203 what it means
Hello thanks for using Fixya
The error 1203 is a cartridge error. It
is an issue that occurs either when a cartridge is bad or the printer cartridge slot is bad
To solve it try this. This solution works
  • Try cleaning the copper contacts of the both carts and cart slot in the printer and try again OR
  • When error shows up, Turn the printer to Power Off. Wait one minute and turn it back on.
Your problem will be solved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
1/28/2011 10:19:12 PM • Lexmark X4250... • Answered on Jan 28, 2011
Lexmark x4250 printer ac adapter
The power adapter for your Lexmark X4250 may not be available in retail stores. I would suggest you contact Lexmark technical support for assistance. Thanks.
12/13/2010 8:48:36 PM • Lexmark X4250... • Answered on Dec 13, 2010
What is the error 1203
The error 1203 is a cartridge error. The cartridge either went bad or you might have bought a bad one. Try turning the power off and unplugging the printer. Then reseat the cartridges. Then plug the printer back into the wall outlet ( do not use a power strip) turn the printer back on. If the issue is still there then try removing and reinstalling the cartridges with the power on. If this still doe not correct the issue try a different cartridge.
Hope this helps..
Best of luck..
11/19/2010 7:46:38 PM • Lexmark X4250... • Answered on Nov 19, 2010
How to install fax numbers in speed dial
go to Lexmark - United States and search for the manual.
10/23/2010 12:24:53 PM • Lexmark X4250... • Answered on Oct 23, 2010
I bought new computer but i lost my cd 4126-k63
driver
9/30/2010 1:56:21 PM • Lexmark X4250... • Answered on Sep 30, 2010
I have a Lexmark X4250...
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
4/25/2010 5:58:07 PM • Lexmark X4250... • Answered on Apr 25, 2010
2answers
X4270 error 1200
Turn off power to the printer and unplug it from the back of the printer.
Insert the power cord back into the printer. You will hear some clicks and motors moving. Pull out the cord again when this happens.Open the cartridge bay by pulling the face forward and lifting the bay door up. The cartridge carousel most likely will not come to the center.By trying physically pulling the carousel to the middle (NOT BY THE RIBBON CABLE) ,if you can not pull it to the middle push it far right as possible. Listen for a click.
After pushing to the right and hearing a click you should then be able to pull the carousel towards the middle easily. Remove the ink cartridges and power up the printer again.You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay.Your problem is fixed.
4/25/2010 7:15:53 AM • Lexmark X4250... • Answered on Apr 25, 2010
I bought another computer, have lost my 4250 disk
You can download the required installation drivers and software from manufacturer's site by clicking this link
On the page which opens, select and download the drivers according to the operating system (Windows XP/Vista,Windows 7) of your computer.
Hope this solves your problem. Thanks for using FixYa.
2/2/2010 5:10:46 PM • Lexmark X4250... • Answered on Feb 02, 2010
Lexmark Fax Machine
Hi you can try see if this works
or
1/30/2010 6:38:34 PM • Lexmark X4250... • Answered on Jan 30, 2010
Lexmark X4250 All-In-One InkJet Printer Logo
54 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
need lexmark 4126
  • Office Equipment & Supplies
