20 Most Recent
Sharp AQUOS Quattron 60 Class LED 1080p 240Hz Smart 3D HDTV Questions & Answers
No sound thru pioneer equaliser from quatrron tv
There are two way to do this.1. Connect all your devices individually to the Pioneer receiver. Doing this allows you so have different sound settings for each input. A reason you might want this is that your DVD will need a DTS or Dolby sound setting so that you get the best audio from your DVD, whereas your TV may only be outputting stereo audio. In this case you would set your Pioneer to a stereo setting. 2. Connect your devices to the Sharp display, then connect the audio output of the Sharp to a free audio input on the Pioneer. Your Sharp LED TV has two ways to do this: a. If you have a digital capable Pioneer sound system, connect using the "Digital Audio Output". You will need a Toslink (Optical) cable for this connection. b. If you only have analog capabilities in your Pioneer sound system, you must use the 3.5mm (1/8 Inch) analog audio output from the Sharp TV to stereo RCA (red and white plugs that are most commonly supplied with home theatre product).
Sharp model GX-CD 610 GY has error 000 what does error 000 mean
The basic binary errors are usually something small. 0000 is usually a cleaning error. I would try to clean the lens with the recommended cleaner and then try again. If problem persists the lens may be saying its dirty due to a scratch on it. These are hard to diagnose because it's a process to remove. I would clean it then replace the lens if needed.
