20 Most Recent
Lexmark X422 All-In-One Laser Printer Questions & Answers
944 service scanner failure
This is a hardware issue. Lamp failure - one or both of the lamps failed, or the CCD cable has failed. Check the CCD cable for proper connection and connectivity. If inspection passes, replace the CCD carriage.
Can you change the fax speed on the Lexmark X422
Why would you want to change it?
When one FAX connects to another FAX, they "negotiate" the speed and capabilities, so as to guarantee a successful data-transfer.
As they negotiate, you may hear the "squawking" soon after the other FAX picks-up the call.
"Service Connection Failed"
Check the most obvious things first:
Is the network cable attached and are the lights on/flashing
Does teh machine have the IP info configured properly or has someone fiddled and messed it up?
Is the phone line connected and operational? So many times the cable has got yanked out without being noticed.
How do i set the time on a lexmark x464
Usually you need to access the embedded web server on the printer by typing the IP address of the printer into your web browser address bar. This will open a window that will have all the settings available.
