20 Most Recent
Lexmark Z715 InkJet Printer Questions & Answers
Only prints green?
Try to "computer clean cycle" otherwise new color print cartridge unless there are separate cartridges for three colors.
No power
If you are encountering power problems with your printer, please go through the following checklist:
- Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
- Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
- Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
- If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
- Make sure the correct power supply is connected to the printer.
Can't get it to turn on
power supply issue.
Lost disk for my lexmark z715 printer and I would
Please
visit the Lexmark website to download and install the
Lexmark Z715 Printer
Driver on your computer. Select your operating system > click on FILTER
> click on the printer driver under Recommended Downloads > download
and execute the file. Simply follow the instructions on your computer
screen.
I hope this information has been helpful.
Should you still need assistance, please leave a comment to my response and
I'll get back to you.
Lost disk to my Lexmark Z715 printer need to
Please visit the Lexmark website to download and install the
Lexmark Z715 Printer Driver on your computer. Select your operating system > click on FILTER > click on the printer driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen.
Should you still need assistance, please leave a comment to my response and I'll get back to you.
Cartridge stall lexmark z705
Please go through the following steps to identify and fix the problem you are experiencing:
- Open the printer cover.
- Remove the cartridges. Check the cartridge area for any foreign objects or debris blocking the cartridge carrier.
- Check behind the cartridge carrier for the encoder strip (transparent strip responsible for the movement of the carrier) and make sure it is seated and not loose in its place.
- Close the printer cover.
- Unplug / re-plug the printer into the power source to reset it.
- When the printer turns on, reinsert one cartridge first. Then close the printer cover.
- Check for any errors.
- If none, reinsert the other cartridge.
- Replace whichever cartridge is causing the error to appear. You may also try to insert a different known working cartridge to identify if it's a faulty cartridge issue.
- If cartridges are good and no error appears, try to print a document to verify that the problem is fixed.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Trouble getting printer to print
Try to delete the Lexmark Z715 print object from the Print and Fax on your Mac 10.4. Then, add a new Lexmark print object. After successfully adding a print job, try to print a document again to verify that printing is working properly now.
My Lexmark Z715 won't communicate
First you need to uninstall it's driver from start menu->control panel->add remove program or program and features if you using vista or win7.
Also uninstall all usb drivers from device manager 1 by 1 then it will automatic install all usb drivers .Make sure usb cable is working fine.
Download it;s driver from below link then install.
Click here
Let me know if you need further assistance.
Thanks for using FixYa.
