20 Most Recent
Linksys EtherFast Cable Modem with USB and Ethernet Connection [ BEFCMU10 ] (104831) Questions & Answers
My ethernet lights will not
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first. Good Luck :)
11/7/2013 1:41:12 PM •
Linksys...
Answered
on Nov 07, 2013
I have a problem with
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first. Best of Luck
11/7/2013 1:38:48 PM •
Linksys...
Answered
on Nov 07, 2013
Have changed to att may I use linksys modem
Yes, you can still use the Linksys router with your ATT dsl modem. Could you provide me with the model or brand of your ATT dsl modem so I could provide you with the steps on how to setup your router?
2/8/2013 10:25:26 PM •
Linksys...
Answered
on Feb 08, 2013
Do I have to call internet co. to use?
If you are going to use this as your modem to bring in the signal from ther internet company so you can connect to the internet, you will need to contact the internet company to make sure that you have the modem configured correctly so the signal can be accepted. The internet company can also give you information about how to set up your computers properly on your network.
I hope that this answer was helpful. If you have any other questions, please let me know.
Brian
2/25/2011 10:33:54 PM •
Linksys...
Answered
on Feb 25, 2011
The ethernet light on my modem turned off despite
Seems like your computer ethernet adapter (network card) is not working correctly/not installed or mis-configured. Open Network Connection and look for Local Area Connection:
* Does it state Disable underneath it? -> Right-click on it and choose Enable.
* Doesn't exist -> Open Device Manager and look for Network Adapters. Is it there? Do you see any yellow question mark or exclamation mark? If so, reinstall the network card driver! If you don't see any of this then the network card is either not connected firmly to the motherboard or it's defective. Connect it firmly (after shutting off the computer and disconnecting the power cord!) or replace it with another network card!
* Exists and enabled -> Right-click on it and choose Properties. Click Configure, go to Advanced. On Media Type, make sure it's set to Hardware Default or AutoSelect.
Cheers,
Pelu.
3/14/2010 2:38:01 AM •
Linksys...
Answered
on Mar 14, 2010
Weak signal from cable modem
if you rent the modem ask for a swap. If you own it ask for a rental roughly 3$ a month. This will give you a way to compare speeds. Have cable company come out and check signal of cable at modem first. The signal should be between +10db to -5db. I wouldn't recomend anything outside that and preffer a +5db range signal. Causes could be damaged line,to many splits to modem etc. You could use a 1000Mhz amp usually 15db's don't use a 900Mhz radio shack or any thing under 1000Mhz for data (internet). 900Mhz is ok for video but I have no desire to own one. Yes modems do **** out in first use or after 5-10 years. Try to use power conditioners or at least a surge protector for anything with a circuit board. Good luck.
3/3/2010 7:57:51 PM •
Linksys...
Answered
on Mar 03, 2010
The send light blinks alot
Well if it works perfect and has no problems then no you don't need a new modem. if it is not doing so well and is messing up a lot then yes i would look into one, Other then that sounds normal for a router or ethernet to be active or none active.
You do got random programs on your pc that do connect to internet while not around or not even using or browsen the net.
7/24/2009 7:56:24 PM •
Linksys...
Answered
on Jul 24, 2009
HELP ME
For any china mobile software like drivers and others, just check
chinamanuals.com - ask them for an english manual for your phone - they will find it for you.
6/1/2009 6:25:06 AM •
Linksys...
Answered
on Jun 01, 2009
Router problem
what is the modem brand / name? maybe you need to get the modem placed on bridged mode first before you can connect the linksys wireless router. check the ip address and make sure it's the ip of the router.
2/2/2009 6:42:55 PM •
Linksys...
Answered
on Feb 02, 2009
US doesn't stop blinking!!!
Heres how i install my modems
1.Turn off all equipment
2. Take an ethernet cable going from the modem, and plug it into the ethernet slot on the computer.
3. plug in the modems power and give it 1 min to power up.
4. Power up your computer and see if it gets connection.
Troubleshooting.
1.Go to the control pannel and look at internet connections.
2. Look for your connection (LAN), and see if is connected.
3. If it isnt connected than it is a problem on your ISP's side.
For other support
1. Call your internet service provider for help.
2. Call the customer support line for the modem.
5/11/2008 5:23:42 AM •
Linksys...
Answered
on May 11, 2008
Frontier router
Frontier Router Login at the bottom of the Network Connections window, just below the address bar. Select Wireless Properties from the menu. Locate the Network security key field on the Security tab. You'll see your Wi-Fi network password if you click the box for Show characters.
1/28/2022 7:46:04 AM •
Linksys...
Answered
on Jan 28, 2022
