20 Most Recent
Kelvinator MDB121RF Dishwasher Questions & Answers
Washing Powder will not flush out well
Start by buying a box of brand name dishwasher powder like Electrosol or Cascade. Use only it, not a cheap generic powder.
Please post back here with the results of this step and we can take the next step if needed. But I bet the step above will take care of your main problem.
Top dishes not getting clean
OPEN THE DISH WASHER AND PULL OUT THE TOP RACK AND SPAY IT OUT WITH AN OUT SIDE WATER HOSE BECASE IT GET CLOG SOME TIME
My dishwasher do not stop at the end of a cycle, it carries on with the next cycle
If your Kelvinator dishwasher is not stopping at the end of a cycle and carrying on with the next cycle, there could be a few different reasons. Here are a few things you can try to troubleshoot the problem:
- Check the timer: Make sure that the timer is set correctly and that it is not stuck in a continuous loop.
- Check the control board: Make sure that the control board is not malfunctioning.
- Check the water level sensor: Make sure that the water level sensor is not clogged or malfunctioning.
- Check the door switch: Make sure that the door switch is not stuck in the closed position.
- Check the wash impeller: Make sure that the wash impeller is not clogged or malfunctioning.
- Check the wash motor: Make sure that the wash motor is not malfunctioning.
- Contact Kelvinator customer support: If you have tried all the above steps and the dishwasher is still not working, it may be best to contact Kelvinator customer support for further assistance. They will be able to diagnose and fix the issue, or tell you if a repair is needed.
