20 Most Recent
Kelvinator 24 in. MDB222RB Built-in Dishwasher Questions & Answers
Kelvinator kd14ss
This is a common problem with this machine. Per the manual E4 indicates that the machine is overloaded but this is incorrect. The machines has actually become water logged due to a design fault whereby some water is allowed to pool at the bottom of the machine rather being efficiently drained. Note that the area where the water pools is not rust resistant. To temporarily overcome the E4 error, tilt your machine backwards and the excess water will drain out the back corners. Remember to put some towels down to avoid a big mop up operation afterwards. I live in a coastal area so drain the machine this way once a month and then open up the back of the machine (don't do this if still under warrantee) to dry it out completely to minimise the rust.
My dishwasher do not stop at the end of a cycle, it carries on with the next cycle
If your Kelvinator dishwasher is not stopping at the end of a cycle and carrying on with the next cycle, there could be a few different reasons. Here are a few things you can try to troubleshoot the problem:
- Check the timer: Make sure that the timer is set correctly and that it is not stuck in a continuous loop.
- Check the control board: Make sure that the control board is not malfunctioning.
- Check the water level sensor: Make sure that the water level sensor is not clogged or malfunctioning.
- Check the door switch: Make sure that the door switch is not stuck in the closed position.
- Check the wash impeller: Make sure that the wash impeller is not clogged or malfunctioning.
- Check the wash motor: Make sure that the wash motor is not malfunctioning.
- Contact Kelvinator customer support: If you have tried all the above steps and the dishwasher is still not working, it may be best to contact Kelvinator customer support for further assistance. They will be able to diagnose and fix the issue, or tell you if a repair is needed.
