20 Most Recent
Logitech Cordless MX Duo 967300-0403 Keyboard Questions & Answers
Re15.2
So, I know these questions are ancient. But I've found the cause of this behaviour in my Cordless MX Duo Keyboard.
This behaviour seems to happen when the batteries in the keyboard move around too much. When shaking the keyboard I get this exact behaviour where it spams "r15.2" with a bunch of other random letters aswell.
The solution would be to secure the batteries firmly. Although I haven't been able to do so yet.
2/23/2019 1:35:58 AM •
Logitech...
Answered
on Feb 23, 2019
Cordless MX DUO charger
try removing the batteries from the mouse and place it in the cradle. If the light lights up or flashes, there can't be a problem with the base station contacts. I have the same problem, but I think the problem is inside the mouse.
2/3/2009 11:47:05 PM •
Logitech...
Answered
on Feb 03, 2009
Keyboard problems
confime if the game is pirated or not. If it is then donot use it any more. If it was a free down load then,it should have finished with its life and may harm your system so discard the game.If it is licenced version of the game then approach the company for assistance and upgradation / advice.
2/2/2009 8:57:32 PM •
Logitech...
Answered
on Feb 02, 2009
Keyboard doesint type
Normal
0
Press the Receiver button (and the lights will start
flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT
button on the back of the board to connect the keyboard to the
receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button
on the back of the mouse to connect to the receiver. Then they
should work okay.
Hope this helps. Bud
1/20/2009 8:52:10 PM •
Logitech...
Answered
on Jan 20, 2009
Keyboard does not respond
open your iTouch configuration dialog box, cordless
tab, press connect, press connect button under keyboard.
should work. i have to do that every time i boot up...don't
know why...
6/1/2008 9:03:33 AM •
Logitech...
Answered
on Jun 01, 2008
Frozen keyboard again
First, change the batteries on both the mouse and keyboard. Reset the connections. Reboot. You should be okay.
2/1/2008 10:56:26 PM •
Logitech...
Answered
on Feb 01, 2008
Logitech wireless combo mouse keyboard mk220
support through bluetooth
• Check the orientation of the batteries inside the keyboard and mouse, or replace the batteries.
• Is the USB receiver securely plugged into a computer USB port? Try moving the USB receiver to a USB port closer to the keyboard and mouse.
• If the USB receiver is plugged into a USB hub, try plugging it directly into your computer.
• Remove any metal object between the receiver and the keyboard/mouse that may interfere with reception. Try using the mouse on a different surface.
• Restart the computer.
• If these suggestions don't work, download the Reconnection Utility from
http://www.logitech.com/connect_utility.
2/28/2024 3:07:39 PM •
Logitech...
Answered
on Feb 28, 2024
How i can connect my logitech wireless mouse EN60950 to the laptop
Unfortunately, EN 60950 is not a Logitech model number. It indicates that the mouse (or other electronic product) was tested and met the European IEC 60950 standard. Here's a copy of a Logitech EN60950 certificate:
https://www.logitech.com/images/pdf/compliance/AGY-700-018651.001_AGY%20CERT%20CB%20HS%20A00086%20BAER%20CI%20(GGEC)_EUROPE.pdf .
Logitech sells several different wireless mice types. Some connect to Bluetooth only. Some connect with a specific USB wireless transmitter/receiver. The dongle is small enough to fit inside the mouse's battery compartment or stay in a USB port when the laptop is moved. (Older Logitech devices used the Unifying USB wi-fi adapter; new ones use the Bolt adapter.) A few models can be used with both Bluetooth and one of the wireless adapters. These can connect to two or more devices and then a single button switches between devices.
Please try to find the actual model of the mouse to get the correct information for connecting the mouse. Logitech support may be able to sell you the USB dongle if they have the correct one in stock.
I hope this helps.
12/8/2023 11:47:00 PM •
Logitech...
Answered
on Dec 08, 2023
