20 Most Recent
Alpine "PKG-RSE2 10.2"" overhead video monitor with built-in DVD pla" Questions & Answers
Arcam Alpha 7 amp. Internal 240v 25A fuse blows
Fuses blow like this due to an overload. The cause being a semi-conductor such as an IC or transistor acting like it was a piece of wire. The most common cause is a shorted output transistor(s) in the main amp. But the power supply can't be ruled out. If you have an ohmmeter then a shorted device will be easy to spot. As it will be just like you have touched the probes together when a part (even in circuit) is tested.
