20 Most Recent
Logitech EXTREME 3D PRO TWIST HANDLE JOYSTICK USB (VG3DPROTWISTJOYSTICKUSB) Questions & Answers
How do I custom program the buttons on a Logitech
I just bought a copy of ControllerMate. Solved all of my button problems with my new Extreme 3D Pro and FA-18 OIF. You can program all the buttons in any way you want. Single key or multi-key entries. I'm running it all on a new MacBook Pro 2.53 Core i5 and it works perfect.
I was astounded that the old 2003 OIF would work on this new intel mac but it does.
Will not work with MS
Both Sim 1 and MS Combat Flight Sim for Windows 95-98 are very old programs that were designed well before this joystick even existed. Add to that the fact that you must run them in compatibility mode and you will understand why they can't recognize the simple existence of the joystick.
Sorry, nothing can be done to fix that. If you still want to use a joystick with this games you need an much older model, preferably one that plugs in a Game Port.
The twist axis doesn't center. i opened the
Please run the calibration utility to re-center your device:
http://www.wingmanteam.com/latest_software/gadgets.htm#Clear Calibration Utility:
If it does not work, then I suggest you to contact the Logitech support for a replacement this is an hardware failure and it's covered by warranty terms.
US/Canada support:
http://www.logitech.com/en-us/contact
European support:
http://www.logitech.com/en-gb/contact
Thanks and have a nice day !
J -
Is there a mac driver for the extreme 3d pro
Here you can find the Logitech FAQ regarding this topic:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=946§ion=troubleshoot&crid=486<_product_id=2965&tabs=1,3,2,4,5&p_search_text=Force%20%203D
Actually this devices functions as HID on mac OSX so you do not need to install any software/drivers.
J -
Logitech Extreme 3d Pro Calibration problems.
Hello There,
Also dont' I meant NO, Do NOT install the software that came with the joystick, it lure a lot problems on calibating and others.
use the game control panel on windows instead.
good Luck
BF2 problem
Recent v1.5 patch install? Assuming this, go to your BF2 Controls, you'll notice a Falcon column to the right of the regular stick assignments... highlite any control in this column which has a preset Falcon assignment, and press Escape to delete all of them. This worked for my Extreme 3D Pro, which had the same problem that you described. I found this solution from another site, so thanks to that gamer for the fix.
LogiExtreme3DPRO
you might need to recalibrate it through the logitech program or even windows in the control panel.
Extreme 3d pro Joystick
Yes, call Logitech support at 1-646-454-3200 they will talk you through it. They were vary helpfull.
Putting back together the logitech extreme 3D pro
it was junk anyway, after about a year or two of service the spring will wear and you will have to send it into logitech, if they cant fix it they will then ask if you want a refund, i would say yes and just apply that money towards a new joystick. My friend had the same joystick and it wore out after two years. he disassembled it, and tried to fix the problem, then he reassembled it and then it didnt work period although everything was ok, so he just tossed it in the trash and bought another one.
