20 Most Recent
Logitech M-SBF96 Mouse Questions & Answers
M-Sbf96, need new driver
Full 32bit installation package -
HERE
Full 64bit installation package -
HERE
Those links will work but if you'd rather do it manually go to there
website
next select the operating system you have, ie, Windows XP
Download from the link provided and install.
Hope this helps.
Logitech mouse M-SBF96 Not Working Properly...
Please uninstall any logitech software version present on your OS (if available) -
Then please proceed to clean boot.
( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 )
-> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if
possible rather than a cordless device.
-> Go to device manager
-> Delete all the USB HOST CONTROLLER -- All of them --
-> The host controller might reinstall them itslef, let the computer handle the reinstallation
-> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for
new hardware " ( The computer with magnifier icon )
-> Once reinstalled, clean boot
-> Reinstall the software if available and/or plug the hardware when needed.
-> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect
the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware
failures are covered by warranty terms
US/Canada support:
http://www.logitech.com/en-us/contact
European support:
http://www.logitech.com/en-gb/contact
Thanks and have a nice day !
J -
Cursor jumps from place to place on screen.
When I have this problem I replace the mouse. You could try going into the control panel and going to mouse and keyboard icon. Try adjusting the settings put 99% It's just your mouse going back.
Good Luck
Proteus
This mouse is jumping around on me
if you are using the scrolling mouse, u can clean the balls of the mouse and use it.
After that i recomend, use the mouse pad for the smooth working of the mouse.
Logitech wireless combo mouse keyboard mk220
support through bluetooth
• Check the orientation of the batteries inside the keyboard and mouse, or replace the batteries.
• Is the USB receiver securely plugged into a computer USB port? Try moving the USB receiver to a USB port closer to the keyboard and mouse.
• If the USB receiver is plugged into a USB hub, try plugging it directly into your computer.
• Remove any metal object between the receiver and the keyboard/mouse that may interfere with reception. Try using the mouse on a different surface.
• Restart the computer.
• If these suggestions don't work, download the Reconnection Utility from
http://www.logitech.com/connect_utility.
2/28/2024 3:07:39 PM •
Logitech...
Answered
on Feb 28, 2024
