20 Most Recent
Samsung Sgh A107 - Gray at&t Cellular Phone Questions & Answers
Wrong card sumsung sgh-a107
If it is an sd card, then remove the one that is thereand replace it. If you need a SIM card, then go to the seller of phones and get one of the right size forcthis phone
Unlock code at&t samsung sgh a107
That actually is a common issue with Samsungs, had that happen to me twice, two different phones. After contacting at&t and Samsung they have no solution or fix. My expert thoughts on the matter are that the code works with the original firmware that came with the phone, but after several firmware updates from manufacturers and at&t it fails. If you knew the exact firmware that was on the phone when purchased and roll back to that it may work, but almost impossible to know. Sorry couldn't help more.
How to openline sgh-a107
Openline for Samsung SGH A107 ia available at
Unlock-zone.com for which you have to provide country and the network it is currently locked and also IMEI number. After that get the code and unlock it.
Unlock samsung a107
hi codes are the best solution to unlock your samsung a107 mobile from network to get codes visit
classicunlocking.com here they ask you the imei number of your mobile .finally they deliver you codes to unlock your mobile.
UNLOCK CODES FOR MY SAMSUNG PHONE
You can get the unlock codes for your Samsung phone at
prounlocking.com ! .You can get the codes by specifying the phone's manufacture, model,country and network. The steps to unlock is simple here and the cost for unlocking is also affordable!!!
How to hard reset Samsung st1000 camera
To hard reset your Samsung ST1000 camera, follow these steps:
Reset Settings via Camera Menu:
Open the camera app.
Tap on the Settings icon (usually represented by a gear).
Scroll down and select Reset settings.
Confirm the reset by choosing Yes when prompted.
Physical Reset (if needed):
Locate the reset button on your camera (refer to the camera's manual for its exact location).
Press and hold the button for at least 10 seconds until the camera restarts
Samsung S9 turning Samsung Music app on by itself
This seems to be a known issue where the Samsung Music app starts randomly1. Here are a few steps you can try to resolve this issue:
Check if an app you downloaded is causing the problem: Start the phone in Safe Mode. If the problem does not occur in this mode, then you need to find out what app this is and uninstall it.
Wipe the cache partition of the phone from the recovery mode: This can often resolve issues with apps misbehaving.
Perform a factory reset: Please remember to backup your phone data before doing this. Once the reset is complete, do not install any apps in your phone yet. Try to check first if the issue still occurs.
Check Power Saving Mode: The power saving mode could interfere and block your music-streaming app if turned on.
If none of these steps work, it might be a good idea to contact Samsung's customer service for further assistance.
