20 Most Recent
Peavey Xr600b Mixer Amplifier "last One" 300 Watt Series 400bh Questions & Answers
How do i use the effects loop on peavey xr 600b?
plug the effects out into the input of your reverb/echo unit, plug the out put of the processor into an unused channel in the mixer, do NOT turn up the effects in that channel, to hear the effects in the main use the main level, to hear effects in the monitor use the monitor level. you must turn up the the effect send in the channel you want to hear the effects on and also the effects master.
Peavey 400B manual
go to Peavey website, select support, select owners manuals, click on archived owners manuals, select x for xr 400 b, select from the shown list.
I have two peavy xr 600b i want to daisy chain them so i can use one for the monitors how do i do that?
you will need 2 y patch cables 1/4in to make this happen, they need to be about 3 ft long, set one head on top of the other...then use a y patch cable and plug it into the main output on both heads, then plug it into the graphic input on the head you want to use for the mains....then take a y cable and plug it into the monitor output on both heads...then plug it into the graphic input of the other head, this one will run the monitors.
Sanpera 1 with Peavey Viper 1 amp - no longer looping
If your Sanpera 1 pedal has suddenly stopped looping on your Peavey Viper 1 amp, it's possible that there's a hardware or internal issue. It's recommended to contact Peavey customer support or a professional technician to diagnose and resolve the problem.
How do I troubleshoot this mic?
Check the coil resistance, first on the capsule (unscrew the front screen) and then on the No. 2 and 3 pins on the XLR.
Now you know....
Probably your membrane coil went away.
That happens, so sorry, but check...
Peace-
