20 Most Recent
Peavey XR 8300 8 Channel Powered Mixer Questions & Answers
How do i hook up monitors to peavey 8300 mixer
Make sure main monitor switch is pressed in, look at back of unit, the speaker jack labeled main/monitor is now monitor output, you may use 2 8 ohm speakers, use controls on front labeled monitors.
Hi i have peavey xr 8300, with no output. It powers up, but no sound ,only a slght hum from the speakers.
Are you good with replacing surface mount components while wearing 5 to 10 power loupes to see what you are doing?
Do you have a controlled heat soldering station, anti static workstation, 100 mhz oscilloscope, audio signal generator, capacitor analyzer, and familiar with reading schematics ???
Do you understand the shock hazards and risk of working on energized audio equipment under test..if so I can start to help you with this repair.
Sanpera 1 with Peavey Viper 1 amp - no longer looping
If your Sanpera 1 pedal has suddenly stopped looping on your Peavey Viper 1 amp, it's possible that there's a hardware or internal issue. It's recommended to contact Peavey customer support or a professional technician to diagnose and resolve the problem.
How do I troubleshoot this mic?
Check the coil resistance, first on the capsule (unscrew the front screen) and then on the No. 2 and 3 pins on the XLR.
Now you know....
Probably your membrane coil went away.
That happens, so sorry, but check...
Peace-
