20 Most Recent
Belkin F8T003 Bluetooth (F8T003V) Wireless Adapter Questions & Answers
Belkin F8T009 will not work
I have had multiple issues with these wireless adapters. I honestly was unable to find supported drivers for windows 7 and ended up getting a new wireless card.
Belkin f8t003 will not work
You were probably using it on an XP or Vista PC. You will need to go to www.belkin.com and download the Windows 7 wireless adapter driver. Go to belkin, support and drivers, put the F8T003 model number in, put Win7 as your operating system, download the driver and double-click on it to install it. Then insert your Bluetooth Wireless adapter in and it should work just fine.
Wirless connection dropped during printing
Hi there
Sounds like your loosing signal periodically, how far is the range on the belkin and are you printing within range? Signal boosters can resolve this although there could be interferance from another device whice is operating close to the wireless frequency or a bad grounding wire can also be to blame
kind regards
Bluetooth adaptor
Hello
here are your driver
http://www.belkin.com/support/article/?lid=en&pid=F8T003&aid=5239&scid=0
I borrowed a belkin bluetooth
the three beeps mean that the device has malfunctioned or is not recognised , try plugging it into another usb port
File transfer
its probably that your comp. can support ur phone files but phone cant support/hold your computer files. local electronics shops could give u more info
Belkin wireless G desktop network card
What has happened is that the proxy server on your last internet connection is in need of being redetected.
you will need to delete any old cookies and internet files, also check in the internet explorer tools>internet options>connection, that the the the last provider you used is trying to connect instead of sky, so either select never dial a connection or sky as your default connection.
Also check that in the properties of the belkin adapter that obtain an ip address automatically is checked in the TCP/IP properties.
You may also need to refresh your browser a few times before you get on the net.
A good temp file and reg cleaner, is Ccleaner, it's free and available at the link below
http://filehippo.com/download_ccleaner/
Compaq presario v6000 network problem
Check to see it hasn't become "Disabled" in Device Manager. if is is, Enable it again.
If necessary Uninstall & Reinstall the "Driver".
Try Booting in Safe Mode with network support... & see if it's OK or not... If it IS OK in Safe Mode, that means that you have a "Driver" conflict to be resolved.
I wonder here if the "Repair Shop" hasn't got some responsibility,indeed it may be something they have done.. or maybe neglected to do.. during the latest "Repair".
I would go back to the shop and politely indicate that it has gone faulty & *never* really worked... (a little white lie) since you got it back.. and it was working 100% A OK B4 they "Fixed" it... & could they please have a look at it for FREE..
If you were MY Client I would have NO problem with that.
Lose wireless internet when printer is on.
the only thing that connects the printer to the internet fault is the fact that the printer and your belkin are both usb connected.
If you are using a laptop then it could be a usb power problem and the motherboard is disconnecting the belkin adapter for some reason, the only one i can think of is a power problem.
The same can apply to a desktop pc if there is a usb problem
Firsly i assume you are using the belkin software to connect the usb adapter to the router, so on your taskbar on the right there is normally the little aerial type icon for the belkin adapter and a little pc screen showing the connection also, if you right click on one of theses icons you should get a line reading 'enable windows WZC', if you do get the option enable it and try using the windows connection software instead of the belkin as it may stop the disconnecting.
Also ensure that when you installed the software to your printer your firewall and antivirus was dissabled as certain elements to the driver may not have been installed.
Lasly, try using different usb ports if you have spare ones, with both the printer and the adapter as sometimes the chip on the board may be instructing the usb ports incorrectly as to which is required first, as windows asks for certain things eg input/output ports to be used first,in other words the IRQ (interupt request) may be causing the problem.
USB device not recognized
Try uninstalling windows version of bluetooth, then re install your adapter driver from the cd, but try in a different usb port.
Win xp drivers
You can download the device drivers for your model Belkin motherboard from the Belkin WEB site.http://www.belkin.com/us/support/update
Mtv music generator detecting directx 7
ok... so I've now installed this on my new pc that i built... first in order to get it to install at all you must download DirectX 7.0 and right click to "--(edit compatibility settings to windows 98/Me and run as administrator)--" remember this as well be doing it a few times. once you do that install DirectX 7.0 and say yes to all. now that this is installed take the .iso file you have and burn it to a cd or DVD-r, once burned you need to go to my computer and right click on the cd/DVD drive, select open (NOT open autoplay), inside the disc menu i want you to go to 2 files... "setup" and "start" need to also have their compatibility settings changed to the above settings. now that these are set stay in the cd menu and double click "setup" this will take you through the setup procedure. after the setup procedure is finished do not view the notes, and continue back to the desktop. now from your start menu load the game and it should run
I cannot connect to the
you need more than a wireless adapter to connect to the internet......
you need a wireless network to connect to. in cafe's and pubs the owner sometimes sets up a WiFi network that their patrons can connect to, however most people have to provide their own.
to get to the internet , you will need.
A broadband connection (ADSL / Cable) this normally comes with a standard NON wifi modem
A WiFi Router (including ADSL / Cable Modem) depending on what you have already.
then to link a remote PC / Laptop to this network, A suitable wireless adapter ( like your belkin adapter)
it is a common misconception that a wireless adapter is all you need (advertising is vague)
